Probably the USB port or cable though...oh well.
Don't Panic! When flashing goes wrong.
Re: Don't Panic! When flashing goes wrong.
I tried to update cwm to the new one from androtab website. Did what they said and renamed it update.zip. Booted the tablet and it said do you wish to update. I clicked ok. It rebooted and the little android man came up with a loading bar.
It loaded to half way and just went blank. Now I get nothing from my tablet. Any ideas anyone?
Sent from my 4.2.2 Xperia S via Tapatalk
if you are on my ROM then if you can get into bootloader flash just the stock recovery.900Supersport
freaktab developer
I'd connect the tab to the PC and see if is being detected at all.
With the flash tool running try holding power for ten seconds, then press and hold vol +, and press power for three seconds900Supersport
freaktab developer
I tried earlier but couldn't get any recognition. I'll double check it again tomorrow.
I'm not too bad with android stuff as i currently test PAC team roms for the sony xperia S so when they did the big 4.2.2 update (stock firmware is still ics) there was a lot of things going wrong to fix non booting. Blank screens etc. So hopefully i can fix this. Just not used to doing much with these tablets
Originally posted by Ben36 View PostI tried earlier but couldn't get any recognition. I'll double check it again tomorrow.
Sent from my 4.2.2 Xperia S via TapatalkREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostI am other Xperia S user, expecting JB on it, I have not this device so I cant help you a lot, read carefully 900supersport post and follow his guidesteeps, he is a "master" in this devices.
What screwdriver do I need to open the tablet? Its like a star shape screw?
Got the tablet back to life without needing to open! Gave it one last try and my laptop recognised it so i had your supersport rom ready to go and whacked flash as soon as it did! Lo
Thanks for your help! :-D
in most cases trying different USB cables, ports or computers will resolve the issue. What OS are you using?900Supersport
freaktab developer
Hi 900ss,
I tried different usb cables and the whole time the same thing: MASKROM MODE and the IDB Failed. No possibility to run my Cube. From the beginning I used your Roms and any problems. On Sundays, with curiosity, I flash ROM Strassen with Arctabletand a few hours later ... a disaster. I use Vista 32 bit...
Best suggestion I can make is
Try rear USB port.
Try different cables
Try stock ROM with flash tool from cubes site
After that it may be a case of opening up the tablet and seeing if there are rest pads. They had them on the original u30gt but not on the mini. On the mini you had to short two pins on the nand.900Supersport
freaktab developer
cube u30gt2 froze after flashing Rockchip Batch Tool v.1.7.
HELP guys!
I tried to flash my u30gt2 (latest model – purchased July 2013 – latest firmware) I used Rockchip Batch Tool v. 1.7. Everything seemed to go OK but unfortunately, when rebooting for the first time the tablet just froze in the original manufacturer logo screen!!!
I tried to reboot, restore etc BUT IT REMAINS FROZEN!
When I connect it on my pc, the device is detected, BUT nothing else happens!
I've tried reset (press volume+ and power button) but nothing happens!
I WOULD HIGHLY APPRECIATE IT IF SOMEONE COULD GIVE A … HAND!
I've tried to locate something in the long and very USEFUL thread, but being new to tablets/Android
I got ... more confused!
That's why I decided to ... post/shout for help!
Thanks a lot
Nick T .
Android 4.2.2
Kernel: 3.0.36+ lcp@tchip-super #36
Thu Jun 6 16:08:57 CST 2013
v2.03 20130606
There are currently 2163 users online. 2 members and 2161 guests.
