Is there any chance to make it alive by this instruction? ... ehh
Don't Panic! When flashing goes wrong.
Re: Don't Panic! When flashing goes wrong.
Rk architecture does not use fast boot as far as I know.900Supersport
freaktab developer
Normal issues as follows
User error
Bad cable
USB 3
Front USB with not enough power
I've a couple of cables that always fail. If I stick to my good cable I've never had a problem.900Supersport
freaktab developer
User fail - nope because I haven't got time for it... I plug and choose good driver at first. Then everything went automatically, and reboot on this step:<Layer 1-1-2> Wait For Loader Start in to Recovery and next <Layer 1-1-2> Wait For Loader Fail
Cable - Short Nokia E52...
USB is 2.0
I tried from my notebook, there is no "front usb",notebook plugged in to electricity
I do all my flashing from my laptop. The list above is based on reports from users.900Supersport
freaktab developer
For me it look's like a problem with loader yep?
**********Upgrade Done Success<0> Fail<1> Time<32277>ms**********
Maybe at first I should install some other because my stock android was old 4.0.4?
That's just my guess...
If you can get bootloader/flash made there is lots we can do.
It's possible you could setup adb on your laptop then use adb to issue a reboot boot loader instruction. You would need to execute an su command first.900Supersport
freaktab developer
rkflashtool, writes, but image doesn't change?
So my original flash failed to get me root. ( did using the windows flash tool included in Finless Bob's ROM )
Was trying to re-flash from linux.
Loaded mk808 in flash mode, seems good - usb recognized.
Code:Feb 7 09:54:12 kernel: [43607.824113] usb 2-2.1.2: new high-speed USB device number 10 using ehci_hcd Feb 7 09:54:12 kernel: [43607.916728] usb 2-2.1.2: unable to get BOS descriptor Feb 7 09:54:12 kernel: [43607.917227] usb 2-2.1.2: New USB device found, idVendor=2207, idProduct=300a Feb 7 09:54:12 kernel: [43607.917231] usb 2-2.1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 Feb 7 09:54:12 mtp-probe: checking bus 2, device 10: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-2/2-2.1/2-2.1.2" Feb 7 09:54:12 mtp-probe: bus: 2, device: 10 was not an MTP device
Code:sudo ./rkflashtool r 0x0051A000 0x00100000 > system2.img rkflashtool: info: interface claimed rkflashtool: info: reading flash memory at offset 0x00619f00
Wrote back original Finless Bob system.img using rkflashtool, again, no errors. Rebooted:
Code:sudo ./rkflashtool w 0x0051A000 0x00100000 < '/home/Documents/MK808 Finless 1.6 ROM/FinlessROM/system.img' rkflashtool: info: interface claimed rkflashtool: info: writing flash memory at offset 0x00619f00
I can't find instructions for doing a more complete reflash from linux. ( for example, rkflashtool or rktools doesn't have an "erase nand" option ....)
i'll try writing the other partitions to see if that has an affect, but I have to guess if system wasn't changing that the others won't either.
thanks in advance for any advice,
s
How did you reboot?900Supersport
freaktab developer
Originally posted by 900supersport View PostHow did you reboot?
no errors there either.
Code:sudo ./rkflashtool b[sudo] password for ...: rkflashtool: info: interface claimed rkflashtool: info: rebooting device...
I used the windows flash tool, reflashed Finless 1.6, and what to you know, it worked perfectly this time. Root works. Go figure.
thanks so much for your reply.
Is this all with the same cable and USB port?900Supersport
freaktab developer
Originally posted by 900supersport View PostIs this all with the same cable and USB port?
Maybe I could look at the C code and see if I can print out more info while the write takes place....
I've a few cables that do not flash successfully. If I'm using a new cable I pull boot or recovery and check that are good files to check before flashing.900Supersport
freaktab developer
There are currently 2104 users online. 5 members and 2099 guests.
