Prahjister Roms MK808 B and non B original and MK808 V5 Realtek and some other stuff
Originally posted by triplesilk View PostPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostI hate to beat a dead horse...but you have a power issue or your stick is bad. try underclocking it to see if it stops the freezing. Get set cpu or something like that and set max to 1.4
In terms of changing the rom posted here, I literally can't click more than two times before it freezes so I can't download an app from the Play store and change the CPU speed.
I'll try to re-flash the Finless 2.1 later and hope for the best.
hi
strange things happens with the sounds of my TV so i was investigating to find if it cames from the TV or the stick ... and i came to android settings and navigate to "sound" and each times it freeze until andoid says "settings doesn't answer..."
don't know what's happening with it, i can set sound by using the bottom bar but can't go in the setting (!)
Any idea ?
doesn't need to read this part
my sound issue:
when i watch a movie (usually with MXplayer but it could do it with other players) sounds is really bad when the sound in video is low (especially when people whispring or scene like that)
there is another sound like when we were using the tapes you know that sort or noise, maybe like wind.
this noise is present ONLY when caracters speak and stop at the same time
it's really annoying because you can't be accustomed to it.
if someone that understand what i'm saying can help^^
Any idea ?
my sound issue:
if someone that understand what i'm saying can help^^Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Hi !
i would like to improve my wifi by adding an external antenna, the following tutorial explain how to do it but i really want to keep using your great rom... so do you think is's gonna be compatible or not ?
for information finless rom 1.7 works but not the 2.1
Minyx Hybrid 2.2.4 works too
regards
regards
hi !
i'm still looking for a way to use a wifi usb stick with rtl8192cu chip with you great rom
i could easily flash another rom but i doesn't want. this one is perfect for me.
i find this https://github.com/ninjablocks/rtl8192cu
maybe it possible to use it to make it work... any idea ?
thanks
My problem is caused by bad quality of wifi signal
not low power
my network:
box -- wifi extender -- mk808b
all of them with static ip
i can buy any model wifi stick if it s compatible with your kernel Nevertheless if could be with the "N" version of wifi and with a big external antenna I ll appreciate
thanks to you
Originally posted by ILoveBugMeNot View PostMy problem is caused by bad quality of wifi signal
not low power
my network:
thanks to youPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by ddn View PostJust dropping by to say thank you for all the hard work you put into making these ROMs, really saved my skin after I tried flashing Finless to my stick before I had properly ID'd it.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
I just tried on my MK808 - RK901, it was previously running Finless BOB ROM 2.1 - Freakstar.
It flashed ok, but booting up stops on the moving firefly lights.
I tried reflashing using the 1080kernel as well, same thing, just sits on the splash screen.
Does anyone have any ideas on how to fix it? failing that - anyone have a link to a stock image please?
thanks
There are currently 2077 users online. 0 members and 2077 guests.
