Here is the stock rom:http://blog.geekbuying.com/index.php.../#.UoR27fsrzrS
Prahjister Roms MK808 B and non B original and MK808 V5 Realtek and some other stuff
Originally posted by kubetts View PostI'm using Prahjster 1.0 rom on MK808B from long time. It works fine. Only problem I have is full storage on 1gb Nand, so I can't install anything more. Is there a way to use 8gb Internal storage (the one called SD CARD) to install apps?
ThanksMy Works @XDA:
AVD Rom Xperia J The Way Stock Should Be
Pre Root Xperia J 4.12
Deodex Xperia L
Deodex Xperia Z kitkat
Stock Xperia Icon's For CM11
You can use internal sd with the same process but it will degrade. Plus by using external sd you keep the system free and fast. It is the best option as all the app data and app cache will be on the second partition and not clogging up the system using up extra ram to store the information and because if you have a big sd you can have a really big partition without sacrificing internal memory.My Works @XDA:
Deodex Xperia L
There are currently 2073 users online. 0 members and 2073 guests.
