Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by Zahir View PostGood lord! A timer? Are the factories out to sabotage us? Can you remove it?
this part of the logcat
D/ConnectivityService( 497): Sampling interval elapsed, updating statistics ..D/ConnectivityService( 497): Done.
D/ConnectivityService( 497): Setting timer for 720seconds
D/dalvikvm( 799): GC_CONCURRENT freed 389K, 22% free 1539K/1964K, paused 19ms+9
ms, total 111ms
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by xc0rpi0n View Postis my first post:
for me this is the best rom for my box (M9 & M8_V0.92), wireless / ethernet, turns off by itself, is worth ......
I hope to fix it .......
the rest is a very very good rom for me.
I bought a square box M8, underneath there is a sticker that says M8N and also it came with the new remote that has learning feature for tv. The firmware is dated 8-28-2014. I'm having issues with bad wifi and interlacing in some video playback. The firmware comes with xbmc gotham 13.2 preinstalled.
Can anyone advise me what's the latest stock rom for this device? Or any other rom which will work good with this device and solve the wifi and interlacing issue? Thanks in advance.
Also, the board inside is the newer v1.0 board which is supposedly the original, with samsung chips.
Originally posted by Zahir View PostI agree - it's a great rom, but...the LAN issue ruins it. Whoever fixes it will gain a large and grateful following.
version 1.1 is out give that a go Zahir.Bugs are Sons of Glitches!
JustMe
Originally posted by xc0rpi0n View Posthello justme, 1.1 is the same rom with the problem of wireless / ethernet lan resolved?
link 1.1b does not work.......
JustMe
Originally posted by manero View PostLink v1.1 beta EM8 -Sqaure 07/10/2014 Off
Not Found
The requested URL /finless/just...1_em8_beta.zip was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
fixed i have fat fingersBugs are Sons of Glitches!
JustMe
There are currently 1922 users online. 0 members and 1922 guests.
