I had this rom and just finished reflashing finless 1.8. I went back because I wanted PS3 controller support and the Ethernet speeds are way better on finless for me.
Sqaure M8 JustMe Roms 20140901 Till Date
SPDIF Output
I'm finding switching between HDMI and SPDIF audio output is not automatic - at least not consistently. To use SPDIF, the surest way is to manually change the audio output in settings and reboot. Auto-detection seems temperamental. This adds an extra step every time you send audio to your DAC or receiver via optical out.
Any way to have both HDMI and SPDIF audio at the same time? I seem to recall you can do this with Finless roms.Last edited by Zahir; 07 October 2014, 21:59.
ok will release one that hopefully should fix the mouse issue and wifi.
hopefully sometime today
spdi unfortunately I don't have amp o try I with
Bajann nt sure about back screen for 2min I reflashed the rom over 10 times and ever countered itBugs are Sons of Glitches!
JustMe
Ethernet issues
Originally posted by JustMe View Postok will release one that hopefully should fix the mouse issue and wifi.
Ethernet is the problem I see. I came from the 20140516 rom. It continuously changed the Mac address on each reboot. For XBMC and my Yatse app, that's a disaster.
Wifi is the same speeds as 20140516. 30-35 Mbps
Ethernet is slower than wifi. 15-19 Mbps
I use it with a HDHomerun Prime. That is working and Mac stays constant.
Fix the ethernet speed and I'll be back.
Thanks.
No big deal - I can set output to SPDIF, and by-pass TV audio altogether. Movies sound great through the hi-fi anyway, just have to turn it on with the TV every time.
So far after a few hours use movie playback and streaming with xbmc is fine,My box is an original square M8 box from acemax and i am not getting the problems with ethernet speeds that some other users are getting.I use Sky Broadband in UK and pay for up to 38Mbps down speed.I have just run a speed test and got 36.12Mbps down and 7.05Mbps up speed, this is looking like a keeper for me.
People after flashing the rom do dalvik data wipe to clear out any old cached settings, this can be done in the recovery mode.Bugs are Sons of Glitches!
JustMe
tooth pick without sd card insertedBugs are Sons of Glitches!
JustMe
OK, can someone explain why this is happening.
Comcast Internet=125+ Mbps
Ethernet connection.
Speedtest= 11.48 Mbps
Transfer 588MB file PC to M8 = 70 Mbps
Wifi 5GHz
Speedtest= 36.74 Mbps
Transfer 588 MB file PC to M8= 30 Mbps
However the file failed due to the wifi disconnecting. Wifi is not holding for me on this Rom.
Originally posted by Icyman View PostOK, can some ne explain why this is happening.
Wifi 5GHz
Justme, can you possibly link to the stock firmware you use for m8n, I haven't been able to find it.
Originally posted by walrusone View PostI had the same thing happening, if it gets fixed I would use this room for sure, but I've gone back to finless 1.8 for now. The other thing I'd like to see in this room is PS3 controller support.
Justme, can you possibly link to the stock firmware you use for m8n, I haven't been able to find it.wifi is ok with this version no drops never
Originally posted by bajann View PostLol,maybe u use all time rom 1.0 M8N?wifi is ok with this version no drops never
sorry to askBugs are Sons of Glitches!
JustMe
There are currently 1905 users online. 1 members and 1904 guests.
