Sqaure M8 JustMe Roms 20140901 Till Date
    have ported and tweaked M8N rom to work on original m8 the rom build is 20140901.
    This is for the following devices:
    - EM8
    - M8
    - TM8
    - M8
    N (need to flash the new remote file if square remote) 2gb, 8gb rom ap6330
    link :Remote updater
    This IS NOT for the Tronsmart/Beelink Round box!!!
    v1.0 Ported M8N for EM8 01/09/2014
    - Ported from M8N to m8 with old remote
    Download :
    JustMe M8N Rom v1.0
    v1.1 beta EM8 -Sqaure 07/10/2014
    - Addressed some issues
    - Some themeing
    - Some Tweaks
    - based on stanes kernels
    - tcp buffers should be fixed, unfotunately i don't have quicker enough broadband to test max speeds
    Known issue's
    - fix 30 second black display after fresh rom flashed
    - Bluetooth lag
    Download : JustMe Rom v1.1b
    v1.2 109k4 ported for EM8 -Sqaure 15/10/2014
    - 720 / 1080 boot screen display - thanks Fineless for the idea
    - Some themeing
    - New Launcher themed my style
    - Some Tweaks
    - Based on Omans kernel
    - TCP buffers should be fixed, I don't have quicker enough broadband to test max speeds
    - 13.2 4k Omans xbmc player
    - Latest netflix now reports api 19
    Known issue's
    Download : 109k4 Ported EM8!
    Do a factory reset after flash
    as always use at your own risk...... unzip onto SD card and OTA update
    if you getting speech to text crashing download load these 2 apks on sd or usb thumb drive
    Google APK Pack!
    v1.2 109k4 ported for EM8 Final -Sqaure 19/10/2014
    - 720 / 1080 boot screen display - thanks Fineless for the idea (cat removed)
    - Some themeing
    - Some Tweaks
    - Latest netflix now reports api 19 gone from 3.80 to 3.81
    - Created APK to fix wake up issue
    - Updated Google services
    - * Add App Deleter
    - Ookla speedtest added
    Known issue's
    - fix 30 to 1min second black display after fresh rom flashed
    Download : JsutMe_109k4_1.2_Fina
    My app- WakeMe Scottie open click on start back out of the app and it should fix your sleep/wake up issues if you have power failure then you will need to redo the steps.
    Next release I will make it auto start service
    Also give it time it will preinstall few apps 5 to 10 minutes, run aptiode to confirm you have upto date apps * don’t update this app unless you want to read chinese.
    v1.3 Stanes s82 ported for EM8 -Sqaure 28/10/2014
    - Some themeing
    - Some Tweaks
    - Bluetooth working
    - Compatiability with certain apps
    - Kernel 3.10.54 Stanes
    Known Issue's
    - fix 30 second black display after fresh rom flashed (Don’t panic)
    - Use Remote updator for square remote posted within this post
    Download : JustMe 1.3 Stane s82 Port
    v1.4 for EM8 -Sqaure m8 beta 21/11/2014
    - Some themeing
    - Some rom tweaks
    - Bluetooth now working
    - WakeMe Scottie my temp app fix for wake sleep
    - few apps added
    Known Issue's
    - fix 30 - 60 second black display after fresh rom flashed (Don’t panic)
    - I have not tested this rom to full extent as I do not have a box readily available these days
    Download :JustMe1.4 Support The Developer Edition
    As always use at your own risk...... unzip onto SD as is and allow few minutes to update
    v1.5 ported v2 for m8 01/12/2014
    - Some themeing
    - Some rom tweaks
    - Fixed sleep/wake up issue no need for wakeMe Scottie
    - All Google and other apps up to date
    - few apps added
    - Gotham with frequency switcher 1.31 thanks to JK-nz
    Known Issue's
    - fix 30 - 60 second black display after fresh rom flashed (Don’t panic) let it update 3 minutes.
    - I people not donating talking about the box sellers who cry poor so please donate show your appreciation.
    Download : JustMe v1.5 v2 port for EM8
    Just unzip and put the 2 files onto the sd card or usb thumb and either do toothpick or update from the andriod ui.
    V1.6 Media Edition for m8 18/12/2014
    - Stripped useless apps & launchers
    - Better performance from all cpu’s
    - XBMC boot Launcher
    - Some rom tweaks
    - Fixed sleep/wake up issue no need for (Wake Me Scottie)
    - Compatibility with certain apps
    - DE bloated google crap only left google play and google play music(also now working)
    - Few utility apps added
    - Gotham 13.2 with frequency switcher 1.31 thanks to JK-nz
    - More memory available 1200 + MB
    - Added confluence customisation mod under skins.
    Known Issue's
    - only for people who have donated, rest of you I will post on forum after new years
    - SD write , usb thumb write is working ok
    Instructions
    Extract onto sd or usb thumb stick, flash either via tooth pick or andriod ui, allow box to stand for 2min so it loads everything and configs
    as always use at your own risk....!
    Download ROM
    V1.6B Media Edition for m8 28/12/2014
    Fixes
    - SD Card write now working
    - Slow net speeds fixed
    - Google play services fixed
    - Game pads now working
    - Few other tweaks
    Known issue's
    blank display for 30 second to 1 minute, introduced the wake up issue again, must use wake me scottie app again.
    Download ROm
    Bugs are Sons of Glitches!
    JustMe
    Smart Move
    Originally posted by JustMe View Post
    I have ported and tweaked M8N rom to work on original m8 the rom build is 20140901.
    download link here :
    JustMe
    Cool - did the download link drop out?
      sorry fixed
      JustMe
        Thank You
        sorry fixed
        Am very interested in testing this. The original M8N firmware ran quite snappily on my M8 but wouldn't hold a network connection (neither Ethernet nor WIFI) for long. Also, I know you and I share a common passion for fast Ethernet; I'm hoping you were able to uprate the TCP/IP buffers.
        Thank you. (I see the non-premium download service is going to be rather slow..)
          sorry if bob gives me ftp accesses to my own folder that he can create on his sever where I can upload the files I will.
          or you have any suggestions
          buffers are
          setprop net.tcp.buffersize.default 4096,87380,110208,4096,16384,110208
          setprop net.tcp.buffersize.wifi 524288,1048576,2097152,262144,524288,1048576
          setprop net.tcp.buffersize.lte 524288,1048576,2097152,262144,524288,1048576
          setprop net.tcp.buffersize.umts 4094,87380,110208,4096,16384,110208
          setprop net.tcp.buffersize.hspa 4094,87380,262144,4096,16384,262144
          setprop net.tcp.buffersize.hsupa 4094,87380,262144,4096,16384,262144
          setprop net.tcp.buffersize.hsdpa 4094,87380,262144,4096,16384,262144
          setprop net.tcp.buffersize.hspap 4094,87380,1220608,4096,16384,1220608
          setprop net.tcp.buffersize.edge 4093,26280,35040,4096,16384,35040
          setprop net.tcp.buffersize.gprs 4092,8760,11680,4096,8760,11680
          setprop net.tcp.buffersize.evdo 4094,87380,262144,4096,16384,262144
          JM
          JustMe
            Can you confirm that the wifi problem is cured in this rom?
            thank you.
              Dark Horse
              Very nice!
              I've been running this ROM on my M8 clone for 3 hours this (early) morning:
              - installs and boots up without a hitch (cute logo..)
              - Launcher (and XBMC) menus are as snappy as Stane's build. The Rom is very quick
              - no issues with wifi so far.
              - Ethernet dropped connection (after I switched my TV to another input for 10 minutes). Will test further.
              -XBMC runs beautifully (tested on 1080p Transformer Extinction) with no sign of interlacing so far
              - 4K YouTube videos play like butter (tested on Shibuya 4k and Assassins Parkour)
              - remote powers box on/off with no issues
              - PlayStore working with no issues
              - excellent throughput moving files from and to external SD and LAN.
              Ethernet not as fast as LifeForce or Finless - but still, ample speed on tap (28 mbps)
              We have a new winner - out of the blue. Thank you, JM, if Ethernet stays up consistently, this is my daily driver.
                I would like to try this but cannot download, all I get is a repeated loop of incorrect downloads.
                  Please upload Mega ou 4shared.
                    I cannot download it either. If I could I would put it on the FreakTab server.
                    Maybe when someone gets a mirror up I will do that.
                    Congrats on the ROM JustMe
                      slow download works ok for me , unless it geo blocked?
                      to reupload this rom would take me 2hrs maybe zhair with fast broadband can or anyone else who downloaded.
                      and thank you Finless still learning and by far less superior from you and leolas, oman, stane,lifeforce, weasser.
                      but by busting chops i learn bit by bit and thank you for the info and the rest of you guys
                      JustMe
                      JustMe
                        It's at 11% now so maybe it will finish. If so I will post it here.
                          25%
                            Thanks JustMe i'm downloading this now to try on my original square M8 box,i'll upload it to Ge:tt or Mega and link here if it isn't breaking site rules.125MB of 412MB downloaded so far.
                              Mirror
                              Bob and others:
                              I've mirrored the file over at Mega. Hope that helps. Am still not sure whether Ethernet holds up or not - I've experienced a couple more drop-outs. However, I'm running this on a H8&M8 V2 box, which may not be typical.
