Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by userofthenet View Post1.5, 1.6, and 1.6B don't require wakme scotie.M8N Quad Core Android 4.4
JustMe v1.5 ported v2
The best ROM
Thank you Justme. This is the best ROM (1.6b) for my EM8. SD card write works great. the box wake up from sleep without any issue. I am not sure why wakeme scottie app is there though. Very smoth all around. I get my max internet speed (50M) when connected hardwired. The wifi speed is a lot slower at 10M but I am not using wifi. I find that it was causing 1.5 and 1.6 to freeze and reboot while hardwired was ok. I didn't try just wifi on 1.6b as I don't use wifi. I had to extract some apps from 1.5 to install on this RoM to make it complete. I am using KODI HELIX and it works well. Now I just need to find out how to make the box boot directly to Helix instead of Gotham. Warning!!! if you want to test Helix, make sure you install another launcher FIRST or you'll end up with a blank screen. For those that like Metro launcher from 1.5. you can extract it from there with an APK extractor such as APPBACKUP AND RESTORE. Also, if you are using Helix from the official site, make sure to change the hardware acceleration to LIBSTAGEFRIGHT only or you'll get audio only when playing videos. Great ROM.
Do you have a gamepad? If you do have a gamepad can you see if it works for you? Everything except gamepad support seems to work on 1.6b for me.
Originally posted by userofthenet View PostThank you Justme. This is the best ROM (1.6b) for my EM8. SD card write works great. the box wake up from sleep without any issue. I am not sure why wakeme scottie app is there though. Very smoth all around. I get my max internet speed (50M) when connected hardwired. The wifi speed is a lot slower at 10M but I am not using wifi. I find that it was causing 1.5 and 1.6 to freeze and reboot while hardwired was ok. I didn't try just wifi on 1.6b as I don't use wifi. I had to extract some apps from 1.5 to install on this RoM to make it complete. I am using KODI HELIX and it works well. Now I just need to find out how to make the box boot directly to Helix instead of Gotham. Warning!!! if you want to test Helix, make sure you install another launcher FIRST or you'll end up with a blank screen. For those that like Metro launcher from 1.5. you can extract it from there with an APK extractor such as APPBACKUP AND RESTORE. Also, if you are using Helix from the official site, make sure to change the hardware acceleration to LIBSTAGEFRIGHT only or you'll get audio only when playing videos. Great ROM.
Reverting from 1.6B to 1.6?
Sorry to say this for me personally, 1.6B created MORE issues than 1.6! constant Boot-Loops and Black screens of Death than I count and its not a matter of patience I have time to burn I spent a whole day testing exhaustively the build I received was dated 27/12/2014 is that the correct one JustMe? I'm waiting until futher debugging has been done but I'm more than happy to soldier on and keep testing new revisions until we can get it Spot-On! Thanks for sharing your work JustMe
Originally posted by f0ck3r View PostHi JustME,
I love your rom but usb keyboards don't work for me and I need them to. Will this be available in 1.6?
Originally posted by dan96815 View PostHi I am using 1.6b anyone know how to turn it off of put the box to sleep?
Originally posted by gsaylor27 View PostAre gamepads working for anyone on 1.6b?
Originally posted by dan96815 View PostSo you don't need wake me scottie?
Originally posted by elgrego View PostI wonder if there will be a c,d,e,f versions of 1.6 before a general release is out lol?
Rome was not built in day.
Originally posted by dan96815 View PostI noticed when the box goes to sleep the network light stay on, on other roms they go off. Is that normal? it won't damage the box leaving them on?
ThanksBugs are Sons of Glitches!
JustMe
I tested with a Logitech F310 and it's a no go for me. I updated busybox before I tested I think because busybox was throwing up some errors. Would updating my busybox stop my gamepad from working JustMe? If it's possible that busybox caused the error than I will go ahead and reinstall 1.6b and test again. Thanks very much for your hard work.
JustMe I was only joking, didn't mean to upset anyoneM8N Quad Core Android 4.4
I've had an OTT m8 for a couple of months and just found this forum ☺ . Must need to read through 39 pages and I'll try my 1st ever custom rom.
Just reading 1st page it looks like 1.6 should be out later? If it goes well I'll be donating.
Will I need anything other than an sd card? Can I just use the remote or will I need a mouse or keyboard?
Cheers
You don't need a mouse and keyboard but it helps a bunch. I use this keyboard/mouse combo:
Originally posted by rs1800 View PostI've had an OTT m8 for a couple of months and just found this forum ☺ . Must need to read through 39 pages and I'll try my 1st ever custom rom.
Cheers
There are currently 2167 users online. 1 members and 2166 guests.
