Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by gsaylor27 View PostAll you need to do is install another launcher for example the launcher from 1.5 or another from Play Store and than select your default launcher from settings.
Originally posted by sparkymark79 View PostHow did you get hold of the launcher out of 1.5?
Ok after reading some of the members pm's, I think 1.6b is ready and will start posting emails with over next few days. change log is on page #1.
+++ As it mentions do not harash Admins, Mods, Members +++
Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostOk after reading some of the members pm's, I think 1.6b is ready and will start posting emails with over next few days. change log is on page #1.
Guest
The wake up issue returns!!! Little gremlins I'm sticking with 1.5 because apart from sd write problem it is great for me 😊M8N Quad Core Android 4.4
JustMe v1.5 ported v2
Running ver. 1.6 and all good. Now I found a manual fix for confluens mod skin for helix, for it to work i need to mod + copy files to this path --> Android/data/org.xbmc.kodi/files/.kodi/userdata/
Funny thing I cant find it, there is something i'am missing, I can found Android/data/org.xbmc.kodi/files - nothing in files folder ...
Tried allso the root/.xbmc/ but couldnt find the /.xbmc folder indside root folder ...
Hmm hope someone have an Ide to what iam doing wrong...
Did a reinstall of the rom - didnt help..
Created the folders manually but that didnt help either
Thanx in advanced
Re: Sqaure M8 JustMe Roms 20140901 Till Date
Sent from my SM-G900F using Tapatalk
my rom will be delayed 2 to 3 days all for good reason I might have found the gremlin so to speak as elgrego mentions for the wake up issue.
but this rom would not suit him since he likes my 1.5 so need to apply elgrego
I wish your new born all the best in lifeand I hope the odd hours you are up is not because of it
stick with my 1.5.
ps "if any new Donator's want a refund tell me and I will refund , the public release will be delayed till 15th Jan 2015 and new donators rom released 2 to 3 days times being festive season holidays"Last edited by JustMe; 29 December 2014, 16:41.Bugs are Sons of Glitches!
JustMe
I've been using it fine simply with XBMC but switching the xbmc screensaver timeout not to dim but to "none" and no timeout amount and then pressing the power button when finished and wha-la! the Blue power LED goes out in 1.6 after a few moments and turns back on when you tap it btw its very responsive! very quick I can't wait for 1.6B! to be released as usual it will be greatly appreciated
P.S. I've donated twice JustMe Once for 1.6 and again when you announced 1.6B and I was thinking of donating again when I received 1.6B as i've tried a lot of other peoples work but I really like how everything "JustWorks" ^.^
There are currently 1869 users online. 0 members and 1869 guests.
