If you redownload latest 1.5v2 and unzip, you then cut and paste recovery file from 1.6v put it in 1.5v2 so you then have 3 files, add them to your sdcard then do the toothpick thing, and all should be good. happy days :-)
Sqaure M8 JustMe Roms 20140901 Till Date
The toothpick thing is not working
"The toothpick thing" is not working anymore after installing rom 1.6
It just looping reboot
I thought same thing but hold the toothpick in for about 6seconds after plugging the power in and it should work. Make sure all 3 files are on your sdcard!
Originally posted by sparkymark79 View PostI managed to get to 1.5 from 1.6 (prefer the launcher)
Originally posted by sparkymark79 View PostThat sounds like something I should do. How did u do that and stop it booting direct into XBMC?
Originally posted by gsaylor27 View PostAll you need to do is install another launcher for example the launcher from 1.5 or another from Play Store and than select your default launcher from settings.M8N Quad Core Android 4.4
JustMe v1.5 ported v2
Originally posted by sparkymark79 View PostYep and DTS if you can support it
You turn on the M8
You start playing a movie...Sound comes out of the TV...connection HDMI
You decide that u want full surround experience....you turn on the receiver 5.1/6.1 sound gets signaled through SPDIF...
TIA
There are currently 2294 users online. 1 members and 2293 guests.
