Sqaure M8 JustMe Roms 20140901 Till Date
    thx very much
    thx very much for all uve done with the m8 mate theres a lot of people that which to thank u very much but theres always people who mess things up stay strong mate keep up the great work ur a star ur roms r the best of the best . happy xmas and new year
      Box.
      I did send you a message yesterday asking for address. or tried as it said you could not accept any more messages. Fire me a message across and I will sort you with a M8N v1 . Have a great Christmas and happy new year.
        Does 1.6 mess up the remote buttons? It did on my m8n on v1.5 and the remote fix fails to install.
        M8N Quad Core Android 4.4
        JustMe v1.5 ported v2
          Remote
          Are you flashing image. then turning box off remove sd card. reboot in to recovery insert sd card do update by ext/sd card m8n new. once done remove card reboot should work.
          That is if you have square remote. Round remote is for old.
            I do the update via the update bit, just like with the rom. I did it the same way on finless and it worked on there, but on 1.5 it goes to recovery by itself and even when I chose the file on sd it starts then aborts.
              all in all well said
              Originally posted by JustMe View Post
              sorry my skills do not extend to developings codes for ignorance or laziness
              NOT?
              RK3288 Devices
              - Overview BOX (LINK !)
                As the saying goes, one bad fish makes the whole basket smells. Guys do you know how much mini x cost compared to enycrap? Justme turned our crappy boxes into mini x with his rom 1.5. Do you know how much money we saved just there? The guy deserves our support with the link or without. Thx Just me for all your support and have a merry xmas everyone.
                  I downloaded the remote update again in a different browser as I noticed the file size was wrong. This time it was correct and the file update still took me to recovery, but this time it flashed. Happy days
                  I'm not in a rush for 1.6 as I'm more comfortable using xbmc as an app and I like the minix launcher. But is there any chance of a port after christmas of v2.00a?
                    Can anyone shed some light upon making gamepads work with JustMe roms? I tried Finless s802 modules but it only recognizes my SNES (SUPER NINTENDO PAD) and I can't get the Xbox lib to be recognized. I tried Finless 1.8 but it didn't run as well as JustMe new 1.5 and 1.6. I'd love to be able to get it to work with 1.5 or 1.6 and this rom would suit all my needs and I'm sure other gamers needs as well. Thanks for any help and thanks JustMe for all your hard work and dedication.
                      Re: Sqaure M8 JustMe Roms 20140901 Till Date
                      What emulator are you using or is it an app?
                      Sent from my SM-G900F using Tapatalk
                        [email protected], your email is bouncing can you pm me with a alternative email so i can send you link been trying last 3 days no luck.
                        Bugs are Sons of Glitches!
                        JustMe
                          Hi all, I've just flashed 1.5 onto my brothers m8n, exactly the same as mine except all of the apps are not there and instead of showing the minix xbmc, it is just the normal Gotham 13.1. I used the same update file that I used for my update? Any ideas please?
                            1.6 version: wifi slow, allways reboots, cant install other roms
                            Hi
                            after installing 1.6 version I have these problems:
                            1. WIFI slow.
                            2. often reboots.
                            3. Cant enter recovery mode - So can not install another rom
                              I sent you a PM with my right email
                                userofthenet is right
                                I agree with you. JustMe does nice work and deserves our support. Ver. 1.5 port 2, installed without a problem and his XBMC fork works as well (if not better than others). Kudos.. cj
                                Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
