Sqaure M8 JustMe Roms 20140901 Till Date
    so that is stanes rom your on not finless?
    Bugs are Sons of Glitches!
    JustMe
      I'm on openelec code snake trying to flash to 1.5 now
      i did try finless to 1.5 no go same code error
      only one that goes from openelec is 1.4 it update no problem
      i get same error leaving open elec and finless to 1.5 rom error keeps popping up
      even acemax or lifefore was no go from openelec
        only one that goes from where I am now is 1.4 it update no problem
        not sure mate seem weird al yankovich to me
        if any other member has had this issue and resolved it please help this member
        I'm to busy trying to push out another update atm to be replicating issues
        JustMe
          Still waiting for my link to 1.6/b, can't message JustMe, because his mailbox is full
          Donation Sent (Unique Transaction ID 3HS273378U8502637) (5th Jan)
            Can anyone who is using 1.5 try this out for the sd write problem? I'm at work so I can't try until tomorrow.
            M8N Quad Core Android 4.4
            JustMe v1.5 ported v2
              Hi JustMe,
              any chance of letting us in on what we can expect in 1.5c?
                Having a little issue with the "ok" button on the remote while watching streams, if i press it while the streams playing, instead of getting the menu bar across the bottom, the Volume appears at the top right instead.
                Is there a fix for this?? I thought i had fixed it because it was ok until after setting "zero cache" in fusion but even when i remove zero cache it still has this problem.
                Anyone noticed this?? Or having this problem??
                Thanks.
                  Thanks.
                  1) do not use zero cache
                  2)Although Im Not a JM ROM user from my general knowledge I Guess u r using confluence custom mod skin the moment its skin related issue change to another skin to solve OK problem...
                    Seems owner forgot the link for the non donators...
                    You did an awesome job! Seems though something went wrong with the link...
                    If you cannot find the link here it's because its not posted and will ne posted on 3rd Jan 2015
                    download : JustMe1.6b
                    Enjoy!
                      JustMe will post the link when he POSTS THE LINK! It's not cool for you to take it upon yourself and post the link for people who have not donated.
                      Anyway I am sure JustMe will post when he is ready. Since I donated already I'll just enjoy the rom and watch something funny.
                        Yes thanks. I have just realized it's a issue with that skin. I always use that one, so i am looking at Aeon Nox but have no experience with it.
                        What do you/anyone recommend as a nice skin to customize.
                        Thanks for the help/advice
                          Azerty's 1.6b link to JustMe's Rom
                          Hi Azerty if you had read what JustMe had posted in this thread, the release has been delayed so politely could you please remove the link. Thanks it's fine for personal use but taking it upon yourself to share here isn't fair on the development... So think of the future support of this device for everyone... Thx
                            So if you use Google, you will see that the firmware has long flowed in public access, I do not support such actions by users as appreciate the work of developers firmware. Waiting for firmware 1.6C
                              ok, so ive finally gotten into recovery mode, (had a bad sd card) but now im getting a error message saying failed to verify whole-file signature. anyone have any idea on what this could be?
                                1.6B Update to Kodi Helix stable?
                                Is it possible to install Kodi and make it work same as That frequency switcher edition which boots straight in xbmc?
