Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by Dermisss View PostBugs are Sons of Glitches!
JustMe
Originally posted by azerty1 View PostYou did an awesome job! Seems though something went wrong with the link...
download : JustMe1.6b
Enjoy!Bugs are Sons of Glitches!
JustMe
Originally posted by freforall View PostHi justme i try your 1.6b for m8box and i only have xbmc 13.2 no more menu with the app, Google play.....if i make a donation for the 1.6 i have all the menu?? googleplay, setting, web browser.....if i have all acces to my box box i'll give you a donation...thanksV1.6 Media Edition for m8 18/12/2014
- Stripped useless apps & launchers
=> this means they are all stripped... (as they are not needed and just consume memory)
but good news you can access them from inside xbmc :
Commands needed:
You can also add "Android Apps" to the main menu by adding.
ActivateWindow(10001,"androidapp://*source/apps/",return)
its all there click on
1. Programs in xbmc
2. Andriod Apps
3. Scroll and select the app you want to exit that app press exit on the app or back buttonBugs are Sons of Glitches!
JustMe
Guest
Originally posted by crowruin View PostMy Gamepad won't Work at all on a Logitech F310 was really hoping it would on this ROM oh wellBugs are Sons of Glitches!
JustMe
Guest
Originally posted by JustMe View PostUnfortunately i do not have one of these but have some idea what is needed for and i hope to implement in 1.6c.I already tried using SetCPU but still nothing.
I also have a PSP Emulator and I can play a few hours of that and the box isn't even hot.
plays perfect on the PSP emulator but when it comes to Android games it freezes.
Originally posted by JustMe View PostNo need to make donation since it gone public.
1. Programs in xbmc
2. Andriod Apps
many thanks again
freforall
Originally posted by elgrego View PostHi JustMe, just wondering are there any major differences from 1.6b and the openlec rom? I only use xbmc on my box so I thought about trying openlec. Also if I decided to go back to an android build, is just a case of flashing back?
Hi
I was wondering before i actually download 1.6b, and i will donate anyway, regardless of link being posted.
Is this a full media edition, as i need to use android file explorer and footmobo apps on mine, can this still be done via the programs app or not.
Just that i like controll it through the android screen to copy and paste files from usb to xbmc folder, and edit advance settings, is this still posible
1. Log into Play Store
2. Download Nova Launcher
3. Press Home button on remote and select Nova as the launcher to use always
You can still use 'XMBC for JustMe', it just won't be your default launcher. You can also install Kodi, and any other apps you want use.
Originally posted by punktunes9 View PostThat should work fine. Think of the app 'XBMC for JustMe' as a launcher, because it is. What I did after installing 1.6B is:
You can still use 'XMBC for JustMe', it just won't be your default launcher. You can also install Kodi, and any other apps you want use.M8N Quad Core Android 4.4
JustMe v1.5 ported v2
No idea whats going on here
Originally posted by JustMe View PostThank you sir for being my representative and acting on my behalf. And what a coward you are hiding behind a fake account, you would of been more of a hero with your real one account
There are currently 2006 users online. 1 members and 2005 guests.
