Sqaure M8 JustMe Roms 20140901 Till Date
1.6B Bootup
The problem described below only occurs on 1.6 and 1.6B.
Sleep/Wake-up works perfectly on 1.6B ... no issues whatsoever. Blue LED goes off immediately and will wake-up when power button is pressed again. However, if I need to remove the power completely, sometimes the ROM will not boot up. There is a small digital clock in the top right-hand corner and that's it, just a black screen. None of the buttons will work. Holding the power will reboot the box and same issue occurs again. Never had this problem with 1.3, 1.4 and 1.5.
Originally posted by zickler View PostThe problem described below only occurs on 1.6 and 1.6B.
Sleep/Wake-up works perfectly on 1.6B ... no issues whatsoever. Blue LED goes off immediately and will wake-up when power button is pressed again. However, if I need to remove the power completely, sometimes the ROM will not boot up. There is a small digital clock in the top right-hand corner and that's it, just a black screen. None of the buttons will work. Holding the power will reboot the box and same issue occurs again. Never had this problem with 1.3, 1.4 and 1.5.Bugs are Sons of Glitches!
JustMe
Originally posted by zickler View Postunfortunately it doesn't. black screen remains no matter what you press. had to downgrade to 1.5 due to this problem.
As one member mentioned I should have soon M8N so this way as he has donated. So can test on both units till then sorry my friend you are a minority with this issue.
and as anyone knows people have mixed results on flashing roms weather it's 100% or 80% different manufactor spec and components are out of my hands if the rom is not developed for that perticular HWBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Post1.5 shouldn't have any issue like this so I think it more related to your hardware you have, sorry to hear that.
Originally posted by userofthenet View PostI found running wifi on 1.5 or 1.6 causes this issue. Running on wired ethernet doesn't cause that
Originally posted by polys View PostWhere can I find the download links for 1.6 or 1.6B?
There are currently 2936 users online. 3 members and 2933 guests.
