Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by brenas25 View Postcan i flash it on my minix 8x-h without problems?M8N Quad Core Android 4.4
JustMe v1.5 ported v2
using v1.5 and its the best android rom i've used on this box by far, is there a way to change the launcher back to the original? not keen on the green xbox looking one. Also tried to revert back to stanes MX linux and I can't get back to it, it flashes ok from recovery but on reboot I just get a black screen is there anything I need to do so I can get back to this, flash a different firmware first maybe?
Originally posted by dsgregorio View Post1.5 is very good. but some things are a lot slower.
and my antutu score was only 15000.
what was yours?
if the box is performing well that all that counts so don't be concerned this has been raised plenty of timesBugs are Sons of Glitches!
JustMe
I have the M8N after updating to 1.5 from finless the remote buttons are mixed up. I downloaded the remote update for my box, but I will not install. I chose it in the update/backup screen, the box goes to the minix screen and then goes to recovery, which should not happen. I decided to choose to update from sd option but it fails.
Somebody must have had this happen?????????????M8N Quad Core Android 4.4
Originally posted by JustMe View PostDon't worry about antutu the chinese fudged there is now way over 30000 bit like how we spoof the box to seem like nexus 10 etc
1.5 is slower than 1.4. But it looks better, works perfectly with my A2 remote. Only think is video (and not audio) sometimes lags on netflix.
and you know some sites like this: http://paletton.com/ ?
the green, blue, red menus could use some styling. Just ignore me if you don't think so. I just want to give a constructive critic.
thanks justme
thanks justme
I appreciate your feedback and is always welcomed , but for freebies , I don't bother too much with styling etc
I only do it for my personal roms and people who have requested and hired me for custom roms
sorry guys allot of work for a freebieBugs are Sons of Glitches!
JustMe
Originally posted by jimmyx View Postany luck with writing to SD cards? or usb drives... this would be handy for backups or pvr purposes or downloading eps for offline viewing....
Just make sure the USB Drive is formatted as FAT32.
Justme, seeing as there is an update to v2 will you be updating this Rom soon ? Pretty pleaseM8N Quad Core Android 4.4
There are currently 2559 users online. 0 members and 2559 guests.
