Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by Still View Postis this on m8n or m8?
Bugs are Sons of Glitches!
JustMe
dalvik cache
hey guys i have this rom and flashed a few times but still no wifi i have both 2.4 and 5 in my house my router is capable of both. OG rom showed wifi but when i put this on no wifi. Ethernet works but only with 10 megs down on a 50 meg down. curious someone mentioned to do a dalvik cache clear. I know how to get into recover via the toothpick reset button way but in there is only wipe data / factory reset and wipe cache which i have done multiple times but i know its really not resetting all settings since each time i go through the set up i had to lower the screen size to 97% that is holding true each time which when i first did the install it was at 100% and i lowered it down to %97 since my screen was not displaying all.
how do i wipe dalvik?
Originally posted by indnracn2 View Posthey guys i have this rom and flashed a few times but still no wifi i have both 2.4 and 5 in my house my router is capable of both. OG rom showed wifi but when i put this on no wifi. Ethernet works but only with 10 megs down on a 50 meg down. curious someone mentioned to do a dalvik cache clear. I know how to get into recover via the toothpick reset button way but in there is only wipe data / factory reset and wipe cache which i have done multiple times but i know its really not resetting all settings since each time i go through the set up i had to lower the screen size to 97% that is holding true each time which when i first did the install it was at 100% and i lowered it down to %97 since my screen was not displaying all.
how do i wipe dalvik?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postgo into recovery with reboot app o toothpick method factory reset, then clear dalvik
thats the thing when i go to recovery mode i select clear data / factory it clears it i dont see an option to actually clear dalvik cache? I have an M8 OTT box if that matters.
Originally posted by indnracn2 View Postthats the thing when i go to recovery mode i select clear data / factory it clears it i dont see an option to actually clear dalvik cache? I have an M8 OTT box if that matters.
clear dat/factory --> delete all user data
also people when posting please post you model number and if you can picture of the pcb to assist any forum member try to help you.Bugs are Sons of Glitches!
JustMe
Try another rom first then update back to 1.4,
m8 ott does tell me much.
try rebooting router or changing router channel even.Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostTry another rom first then update back to 1.4,
crap now its bricked i think. I put finless on and then when coming back to 1.4 it took the flash - rebooted and then nothing on the screen. Blue light turns on but display blank says no input on screen. Is it bricked? I am not having any luck with this darn box. Any ideas?
Originally posted by indnracn2 View Postcrap now its bricked i think. I put finless on and then when coming back to 1.4 it took the flash - rebooted and then nothing on the screen. Blue light turns on but display blank says no input on screen. Is it bricked? I am not having any luck with this darn box. Any ideas?
too pick, post pictures of your box my friend as mentioned before inside and outsideBugs are Sons of Glitches!
JustMe
Originally posted by indnracn2 View Postsorry my friend here you go.
[ATTACH=CONFIG]8943[/ATTACH][ATTACH=CONFIG]8944[/ATTACH][ATTACH=CONFIG]8945[/ATTACH][ATTACH=CONFIG]8946[/ATTACH][ATTACH=CONFIG]8947[/ATTACH][ATTACH=CONFIG]8948[/ATTACH][ATTACH=CONFIG]8949[/ATTACH]
you also do know in my notes there is a 30 to 1 minute delay of black screen before it goes into settings?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postlooks liek box from SZ Tomato, load up finless rom on to sd card the recovery, zip file and the factory param file and do the toothpick in the av and it should automatically start to flash the finless rom
update
i tried recovery from yours used toothill blue light on no display on tv left on 1 hour and rebooted still nothing after.. will not update. so which recovery should i try ?
There are currently 2429 users online. 0 members and 2429 guests.
