Sent from my SM-G900F using Tapatalk
Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by JustMe View Postwhat box how can I provide a solution and what first screen do you mean?
For me the best update is the 1.3...
But now am looking for a fix for bluetooth & wifi.
Thx again !
Re: Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by Neokrome View PostI use The M8 Box s802 and i have a Freeze on Boot Logo Screen...waiting 10 minutes but nothing.
Thx again !
Originally posted by Deezel View PostStill trying. Using thumb drive toothpick method on trmk1 unit. All seems well until reboot. It seems to be stuck on the minix boot screen and goes no further.
try t via the android ui update should okBugs are Sons of Glitches!
JustMe
Originally posted by skratch View Post@Justme just sent you a drink, have aon me mate...
JustMe
Originally posted by indnracn2 View PostHey guys I posted a while back post #390 but loading 1.4 seems to have bricked me anyone point me in right direction to unbrick box? Blue light turns on but nothing on screen and toothpick trick does not get me into recovery. any help is so much appreciated.
Originally posted by gsaylor27 View Post... having an issue where my external SD will not allow RW, it's stuck on RO. I have tried ext4, ext3, and ext2 with no luck whatsoever. ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by bajann View PostMashup dont work on that version xbmc,i try spmc work with eror 404,minix launcher realy i dont like ,problem on browser dont want to go down when i want to go to settings on the top ,in xbmc when i go to sistem info i see i have free only 600-800mb ram memory do u see that?sry on my bad eng.ty for grate rom
ps i like colors
JustMe
Originally posted by JustMe View Postthe xbmc wouldn't have anything to do with the plugin I could be wrong have you tried it on any other rom you will find you get same errors
Help required
Originally posted by Neokrome View PostOk I try the 1.3 and have no problem (just no wifi & no bluetooth but its nothing)
1.4 freeze on first screen
1.5 freeze on first screen too
wainting for a solution...i hope...
Thx !
I am also facing similar issue as above. My box is SmartV, similar configuration, wifi is using rtl8188eu. with 2gb/8gb
The 1.3 works fine without wifi & bt
1.4 does not boot hangs at boot logo
1.5 does not boot hangs at boot logo
Please provide a fix.
regards
I'm currently on finless 1.8, can I just update to this via the update option in the launcher settings?M8N Quad Core Android 4.4
JustMe v1.5 ported v2
Originally posted by elgrego View PostI'm currently on finless 1.8, can I just update to this via the update option in the launcher settings?Bugs are Sons of Glitches!
JustMe
There are currently 3888 users online. 1 members and 3887 guests.
