Sqaure M8 JustMe Roms 20140901 Till Date
all down new like update first pageBugs are Sons of Glitches!
JustMe
Crown Jewel
First impressions - simply outstanding. Interface is fast and smooth, 1080p video is fluid and vibrant, a/v sync is spot-on. XBMC rocks on this rom. Maybe I'm up too late, but things seems to run better on the M8 than on the parent Neo 8. I have both and can compare. One thing is certain: HDMI-CEC works better on the M8.
Ethernet speeds around 97 mbps down, 27 mbps up, home network file transfers around 5 - 6 mbps - nothing shabby there...
This is your coronation, JM!
Originally posted by Neokrome View PostOk I try the 1.3 and have no problem (just no wifi & no bluetooth but its nothing)
1.4 freeze on first screen
1.5 freeze on first screen too
wainting for a solution...i hope...
Thx !Last edited by JustMe; 02 December 2014, 10:05.Bugs are Sons of Glitches!
JustMe
Thanks for such quality work. I'm having an issue where my external SD will not allow RW, it's stuck on RO. I have tried ext4, ext3, and ext2 with no luck whatsoever. I haven't had this issue with any other ROM created by you or any other delveoper. I went back to the last working ROM with a multi partion SD (JustMe1.4) and it works. JustMe do you have any input or anyone else kind enough to help on this issue. Thanks very much..
xbmc
Mashup dont work on that version xbmc,i try spmc work with eror 404,minix launcher realy i dont like ,problem on browser dont want to go down when i want to go to settings on the top ,in xbmc when i go to sistem info i see i have free only 600-800mb ram memory do u see that?sry on my bad eng.ty for grate rom
ps i like colors
Originally posted by bajann View PostMashup dont work on that version xbmc,i try spmc work with eror 404,minix launcher realy i dont like ,problem on browser dont want to go down when i want to go to settings on the top ,in xbmc when i go to sistem info i see i have free only 600-800mb ram memory do u see that?sry on my bad eng.ty for grate rom
ps i like colors
JustMe
Originally posted by gsaylor27 View Post
Thanks for such quality work. I'm having an issue where my external SD will not allow RW, it's stuck on RO. I have tried ext4, ext3, and ext2 with no luck whatsoever. I haven't had this issue with any other ROM created by you or any other delveoper. I went back to the last working ROM with a multi partion SD (JustMe1.4) and it works. JustMe do you have any input or anyone else kind enough to help on this issue. Thanks very much..Bugs are Sons of Glitches!
JustMe
There are currently 2284 users online. 2 members and 2282 guests.
