Sqaure M8 JustMe Roms 20140901 Till Date
    Re: Sqaure M8 JustMe Roms 20140901 Till Date
    Originally posted by JustMe View Post
    fixed
    , trying now , thank u., feedbacks [email protected] this android rom gives life to my M8..
      Not updating
      Is it just me or is anyone else having problems flashing 1.5? i did notice there is no recovery file in the zip so tried another but still nothing. it looks like its updating but then just restarts on the 1.4.
        Doesn't work updating I got error saying can't install old software over new
          Same here... on my H8M8 box, just returns me to my current rom, after a short load and erase.
            try loading old finless rom or lifeforce or even stock rom
            Bugs are Sons of Glitches!
            JustMe
              I try 6 times heheh
                Tried with your own excellent 1.1, JM - no dice..
                  ok sorry my mistake new update this one has been confirmed by friend 1hr and 20min upload time, I have deleted old file to save server bandwidth.
                  JustMe
                    Did same for me. Tried toothpick, update and normal recovery
                    Maybe TWRP recovery may work?
                      Same here ..same error as everybody else...just to show @justme.cannot install this package over a newer build...???tried both toothpick method and update method didnt work...thanks.
                        Tried with stock and finless and unfortunately still no go. 😢
                        Sent from my SM-G900F using Tapatalk
                          I also tried the stock and finless rom and no go either
                            35 min new fixed rom will be up
                            JustMe
                              Thanks for the effort i will try it in the morning (here)
                                Thanks for your [email protected] to sleep..will have a go again tomorrow..thank u.
