TREID USING TIS ROM BUT IT STICKS ON MINIMX SCREEN ANY IDEAS GUYS...I GOT A UM8 BOX
Sqaure M8 JustMe Roms 20140901 Till Date
Re: Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by dsgregorio View Posthi. after updating to 1.4, i can't go into recovery mode anymore.
so, toothpick update is not working.
tried the update app and it recognizes the file inside SD, but when i click update, it just reboots.
any solution to this problem? how can i change it to 1.5?
thanks!Three days of testing can save 10 minutes reading manuals
Hi, thanks for your rom, nice work. I've made a donationi've installed 1.5 but one issue i have is if i do a factory reset the box no longer boots, it displays the logo then the boot animation but doesn't get any further. I noticed the same thing on earlier version as well. Does anyone else have this issue? Not a major problem as i can just re-install but just wondering why a factory reset breaks it and if there is a fix, unless it's just me - no pun intended
Does anyone else have same issue as DLXS ? help the guy out since I cannot without box handyBugs are Sons of Glitches!
JustMe
Originally posted by dlxs View PostHi, thanks for your rom, nice work. I've made a donationi've installed 1.5 but one issue i have is if i do a factory reset the box no longer boots, it displays the logo then the boot animation but doesn't get any further. I noticed the same thing on earlier version as well. Does anyone else have this issue? Not a major problem as i can just re-install but just wondering why a factory reset breaks it and if there is a fix, unless it's just me - no pun intended
ThanksThree days of testing can save 10 minutes reading manuals
Google Apps not working ?
Had a question for folks with V1.5 installed... I've been having issues with Google apps and have tried several suggested solutions- Clear cache/ data and remove / reinstall for Google Play Services and other offending app.
App that don't work:
1) Google Play Music - just force closes
2) Google Movie and TV - plays previews and trailers , but content from My Library fails
3) Google Voice Search sometimes force closes or when it does work and provides search result, it will display them then force close a few seconds later.
4) Google+ can't be found in the Play Store or when it is side-loaded or installed from another source - fails and says - "Install Failed missing shared library"
5) Google Books and YouTube work OK
Wondering if other folks have this problem ?
Have seen the same issue in this ROM as well - M8 ROM - S82 NCv2 (Custom) so it may be changes for security of DRM content , applications security sharing (Google Settings) , etc made by Google causing the issues.
Any suggested fixes or is it an issue like the SDcard not being writable and the blue light stating on where the ROM needs to be fixed ?
Really like this ROM, so not willing to give it up yet.
Originally posted by dy57 View PostHad a question for folks with V1.5 installed... I've been having issues with Google apps and have tried several suggested solutions- Clear cache/ data and remove / reinstall for Google Play Services and other offending app.
I believe most new roms will have an issue with ooogle stuff from now on not sure if its a counter measure or aml sdk issue without box not much I can do.
anyone else have this issue with current roms?
or old rom with current google play and google music crash?
I think it more the goole lvlLast edited by JustMe; 06 December 2014, 12:07.Bugs are Sons of Glitches!
JustMe
Originally posted by bajann View Posti just must to know maybe i have low ram memory or something like that plz if someone want to try antutu or just look in xbmc to see free ram space i got 600mb free ram memory with jusme 1.5 With all other roms i got about 1.2gb free memory.Bugs are Sons of Glitches!
JustMe
Just installed 1.5 over finless without any problems. Now copying the xbmc data back over all before Liverpool kickoff. Thanks
Update: I can't write to the sd card and I also tried to update the remote via update option but it takes me to recovery for some reason so I selected the update that way and it fails. Any ideas?Last edited by elgrego; 06 December 2014, 16:05.M8N Quad Core Android 4.4
JustMe v1.5 ported v2
thanks!
There are currently 3535 users online. 0 members and 3535 guests.
