Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by bajann View Postmaybe u have bad download
I have cleared the cache and upgraded, now its stuck on a boot loop and i cant get in to recovery mode again!
Originally posted by skratch View PostI did think that Bajann so i downloaded it again, i have tried both sd card and usb, its saying it cannot mount sd for some reason?
Re: Sqaure M8 JustMe Roms 20140901 Till Date
Originally posted by Damian99 View PostNot having the best of times with it myself mate, seems to boot straight into xbmc which i sure it shouldn't do?? Can't get back in to recovery mode.
As for me I push in the button put the power in then it shows the m8 sign then just loops. So I think I have f#ck@d it up!
Sent from my SM-G900F using Tapatalk
Originally posted by skratch View PostThat is the idea of this rom I believe and then you get to your android apps via the programs option.
I have seen people recommend this mate........... you can try it for nothing ??
initially I was thrown off as it booted directly into XBMC but after playing around with this FW more and more I learned to actually love it! Lets face it we use these M8's for Streaming media right? So why clutter it up with the android boot initial boot up menu it just added an extra step for me to start XBMC.. It also gave my customers more chances to F up the units when they started messing around with the settings
I like how you can access all the apps from the Android Apps section in the Programs tab, and if you really need to get to the M8 settings you just select the MboxSettings from the list of apps and bam your in the settings screen
Hopefully everyone is enjoying this FW as much as me
Originally posted by Damian99 View PostNot 100% certain but is that firmware EM8 only?? Maybe someone can confirm it's ok on the M8 you have??
Yes, it says in the initial post:
Originally posted by JustMe View Posthave ported and tweaked M8N rom to work on original m8 the rom build is 20140901.
This is for the following devices:
- EM8
- M8
- TM8
- M8N (need to flash the new remote file if square remote) 2gb, 8gb rom ap6330Last edited by MKMutual; 20 December 2014, 16:21.
There are currently 2091 users online. 0 members and 2091 guests.
