Joking, but seriously my ethernet speeds died, can't stream properly through plex, stuttering and freezing, I'll play with it a bit more but something is definitely screwy on my system with your latest rom.
Sqaure M8 JustMe Roms 20140901 Till Date
Just tested Wifi and Ethernet Speeds, tested same as first release of Rom using ookla.
Direct Connect in wifi settings cant recall seeing that before ?
Has been awhile since i have had a good fiddle with my M8
A few hours had a good fiddle, No doom and Gloom, all working well XBMC, Plex, Netflix,
Apps in Well Done JM ready for your next project and no pussy footing around
Cheers
perfect
I didn't use the tooth pick method and everything is working perfect so far. I installed from setting. Once the update finished the system rebooted and I got the google service error. I ignored it and preformed factory reset and the next boot no more errors. Then I turned on the scottie wake me. So far it is running very smooth. No interlace or stuttering in xbmc and no network drop out. My ethernet speed was 77m down and 8m up. I turned off the unit and was able to wake it up but I only waited 2min and when I did wake it up it was from a usb air mouse which might mean the unit is not in real sleep mode as only the IR remote was able to wake it up from the deep sleep in other ROMs. I will leave it off overnight and see in the morning. Honestly, if the unit stays cool I wouldn't care of it is in deep sleep mode or not..... I am a cat lover but I have to admit the new vbox logo looks better. I still don't see the Bluetooth in the setting but I don't use any Bluetooth device so that is not an issue for me. In conclusion, this is the perfect ROM I have been waiting for. Thank you justme.
Originally posted by userofthenet View PostI turned off the unit and was able to wake it up but I only waited 2min and when I did wake it up it was from a usb air mouse which might mean the unit is not in real sleep mode as only the IR remote was able to wake it up from the deep sleep in other ROMs. I will leave it off overnight and see in the morning
Originally posted by userofthenet View Postthe unit never woke up in the morning. I guess the power issue is still there for me.
was the Turn on button still shaded out or not?Bugs are Sons of Glitches!
JustMe
Originally posted by userofthenet View PostBefore turning the unit off last night the turn on button was not shaded. I didn't turn the unit on this morning to see if it is still greyed out (not shaded).
I only tested it for 1hr which to me it works because prior to the app after 12min the box would not wake up
only other thing i can think of is the andriod task manager after while when resources are low it scraps the app.
cannot test at the moment as I'm working on the linux rom and have it loaded on my box
maybe some other member who loaded it can adviseBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postbutton must be (greyed out as if you pressed it) before backing out of teh app.
Originally posted by dy57 View PostI pressed the Turn On button in the Wakeme app then backed-out. Checked the app a couple of minutes later and the Turn On button was not grayed-out. App was still active in the task manager and in Settings/Applications.
So did anyone else have the ethernet/wifi issues with the newest justme rom. I found it strange as I have had excellent speeds since his second update and now I'm having issues. For now I flashed back to finless 1.8. I may tried to do another clean flash tomorrow, but I'm doubtful it will change anything as I flashed it twice already with the same resulting slow ethernet/wifi speeds.
Originally posted by walrusone View PostSo did anyone else have the ethernet/wifi issues with the newest justme rom. I found it strange as I have had excellent speeds since his second update and now I'm having issues. For now I flashed back to finless 1.8. I may tried to do another clean flash tomorrow, but I'm doubtful it will change anything as I flashed it twice already with the same resulting slow ethernet/wifi speeds.Last edited by userofthenet; 21 October 2014, 04:25.
There are currently 2608 users online. 0 members and 2608 guests.
