what am i doing wrong?
CX-919 Help
Help
Hello. CX919 clone Rk3188T http://www.kephost.com/image/WiC
Finless 1.6b rom flash . brick . How to original rom?
http://kepfeltoltes.hu/view/141001/S...toltes.hu_.png
Please helpLast edited by kukszi; 13 October 2014, 19:28.
Originally posted by kukszi View PostHello. CX919 clone Rk3188T http://www.kephost.com/image/WiC
Please help
https://drive.google.com/file/d/0B3M241oG557VOU1vbDlib0xDVnM/view?usp=sharing
I've only been able to flash it with the following procedure.
1. from windows with rkandroidtool v1.37 erase idb and flash parameter and loader.
2. from linux with rkflashkit flash misc, boot, kernel, recovery and system.
3. after sucesfull flashing, boot android and go to system/storage, there you have to mount internal nand and format it
Hope it works for you and I hope somebody finds a way to install kitkat
cx919
Hello. Thank you . I managed to find another operating cx919. Kitt Katt 4.4.2. Rom http://kepfeltoltes.hu/view/141018/r...toltes.hu_.jpg backup ROM Help?
Originally posted by kukszi View PostHello. Thank you . I managed to find another operating cx919. Kitt Katt 4.4.2. Rom http://kepfeltoltes.hu/view/141018/r...toltes.hu_.jpg backup ROM Help?
hard bricked?
Please help
Originally posted by kukszi View PostNo link. This is another cx919 stick. We need to save it to rom. Rom dumper.
lmmf12 thank you. Operates the rom you sent. But there is no nand flash. How do I reformat?
No possibility the of getting that rom? Could you dump it? do tou need any help on dumping the rom?
Originally posted by kukszi View PostYes Help me dumping the rom
do you have a working linux installation? It's much easier to dump the partitions in linux.
in a quick way i'll tell you that you should dump the parameter file and the bootloader from windows with rkflashtool 2.1.
then go to linux and dump the partitions with rkflashkit.
These are the instructions to dump it from windows by Finless.
http://www.freaktab.com/showthread.p...ew-RK-2-1-tool.
at least you should dump the kernel image file and we could try and make it work in another rom.
Keep me informed please.
cx919
mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x 00008000@0x00004000(kernel),0x00008000@0x0000C000( boot),0x000C000@0x00014000(recovery),0x00100000@0x 00020000(backup),0x00040000@0x00120000(cache),0x00 400000@0x00160000,0x00002000@0x00560000(kpanic),0x 00100000@0x00562000(system),-@0x00662000
Please specify which number to write and could start android tool 2.1 misc ,kernel,boot, recovery,system dumping.
I'm sorry I do not speak English. I use Google transalate
Originally posted by kukszi View Postmtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x 00008000@0x00004000(kernel),0x00008000@0x0000C000( boot),0x000C000@0x00014000(recovery),0x00100000@0x 00020000(backup),0x00040000@0x00120000(cache),0x00 400000@0x00160000,0x00002000@0x00560000(kpanic),0x 00100000@0x00562000(system),-@0x00662000
2. choose misc partition in download tab.
3. go to advanced function tab: start:0x00002000 count:0x00002000
4. press export image button
5. rename exportimage file in output folder as misc.img
2. choose kernel partition in download tab.
3. go to advanced function tab start:0x00004000 count:0x00008000
5. rename exportimage file in output folder as kernel.img
2. choose boot partition in download tab.
3. go to advanced function tab start:0x0000c000 count:0x00008000
5. rename exportimage file in output folder as boot.img
2. choose recovery partition in download tab.
3. go to advanced function tab start:0x00014000 count:0x0000c000
5. rename exportimage file in output folder as recovery.img
2. choose backup partition in download tab.
3. go to advanced function tab start:0x00020000 count:0x00100000
5. rename exportimage file in output folder as backup.img
2. choose system partition in download tab.
3. go to advanced function tab start:0x00562000 count:0x00100000
5. rename exportimage file in output folder as system.img
And you have finished, we don't need the resto of partitions.
You should have in the output folder:
bootloader.bin
parameter
misc.img
boot.img
kernel.img
recovery.img
syste.img
backup.img
Now you should be able to flash it to the other stick
Pleeeeeeaaaaseeeeeee share your dump.
thank you
P.D. YOU DON'T NEED TO DUMP THE BOOTLADER.
There are currently 2312 users online. 1 members and 2311 guests.
