CX-919 Help
KITKAT 4.4.2 ROM FOR RK188T CLONE GXT D16 LP
Well here's the kitkat rom. <<<<KITKAT ROM CLONE GXT D16 LP>>>>
To flash it I have used Finless rom flashtool 1.37 that I attach to the rom zip file.
1. Check the following options:
loader ............loader213.bin located in ouput directory.
parameter ........parameter.txt
misc
kernel
boot
recovery
cache
metadata
kpanic
system
backup
userdata
2. uncheck
user
dummy
3.Erase nand idb
4.flash rom.
I hope it works for everybody.Last edited by lmmf12; 22 October 2014, 00:02.
Originally posted by kukszi View PostHello. Yes kitt-katt works . no nand flash . No eraseInternal flash storage sef to remove
Go to settings , then to backup and reset, factory data reset, check erase nand flash and press reset device. It'll reboot and after that nand will be formatted and working.
Kitkat?Originally posted by dragonjah View PostI have the same stick. You will find the last ROM version here.http://www.thetabletexpert.com/suppo...0923_16g2g.img
nice
Originally posted by kremlincrackers View PostThe rom 4.4 works on my device, oh yes! It's the original romThanks
Now, a few mirrors
http://multiupload.biz/5kvvlt78rual/...16g2g.img.html
There are currently 2061 users online. 1 members and 2060 guests.
