CX-919 Help
Originally posted by OnlineTuba View PostThat is rom I am currently using but bluetooth and Wifi are not working and I can seem to mount the nand flash. how can I flash back to Jellybean?
Hear is the correct kernel I have found for your device wifi chip RTL8723BS^ download & unzip the kernel.to a safe place on your pc where you no where it is,.
Open Flash Tool v1.37 untick everything except kernal, on the kernal line to the far right is a little box click in that box & locate the kernal you downloaded select the kernal you require
Put your stick into flash mode the easyest way is to use the reboot app https://play.google.com/store/apps/d...s.reboot&hl=en & select reboot to bootloader (flash mode)
At the bottom of flash tool it should say "found RKAndroid Loader Rock usb" or something similar ,
So now all thats left to do is click flash rom it will only take 3 or 4 seconds & your stick will reboot with your new kernel & you wont loose anything on your device your device we stay the same apart from having a new kernel,,, hopefully you will now have working wifi & Bluetooth.Please consider making a Donation to freakTab
Originally posted by OnlineTuba View PostThanks for your help still no luck no wifi or bluetooth.Please consider making a Donation to freakTab
Originally posted by alephis View Postlooks exactly like my device. try this http://pan.baidu.com/s/1sjykrwh firmware.
my also has problem with video and youtube decoding playback but this is hardware, not software problem.
Also thanks to blinkone for your help also.
Originally posted by OnlineTuba View PostThis Rom worked thank you for the link, do you know if there is a root available for it?
I think rooting should not be any different from rooting other similar devices.
Originally posted by hypermind View Postcant see anypins on samsung chip...
14:22:03 491 <Layer 1-1-2> Test Device Start
14:22:03 491 <Layer 1-1-2> Test Device Success
14:22:03 501 <Layer 1-1-2> Lowerformat Device Start
14:22:31 517 <Layer 1-1-2> Lowerformat Device Success
14:22:31 521 <Layer 1-1-2> Test Device Start
14:22:31 527 <Layer 1-1-2> Test Device Success
14:22:31 532 <Layer 1-1-2> Check Chip Start
14:22:31 538 <Layer 1-1-2> Check Chip Success
14:22:31 572 <Layer 1-1-2> Get FlashInfo Start
14:22:31 577 <LAYER 1-1-2> INFO:FlashInfo: 0 0 0 1 0 10 10 28 2C 2 3
14:22:31 582 <Layer 1-1-2> Get FlashInfo Success
14:22:31 589 <Layer 1-1-2> Prepare IDB Start
14:22:31 593 <LAYER 1-1-2> INFO:CS(1) (8192MB) (HYNIX)
14:22:31 597 <LAYER 1-1-2> INFO:CS(2) (8192MB) (HYNIX)
14:22:31 613 <Layer 1-1-2> Prepare IDB Success
14:22:31 619 <Layer 1-1-2> Download IDB Start
14:23:01 246 <Layer 1-1-2> Download IDB Success
14:23:01 246 <Layer 1-1-2> Reset Device Start
14:23:02 258 <Layer 1-1-2> Reset Device Success
14:23:02 265 <Layer 1-1-2> Wait For Loader Start
14:23:33 000 <Layer 1-1-2> Wait For Loader Fail
14:23:33 000 **********Restore Done Success<0> Fail<1> Time<89497>ms**********Last edited by OEMBSOD; 04 January 2015, 21:43.
HELP...
Good afternoon.
I hope not call abuse ask you for help in this way.
I have a CX-919, and I can not in any way make stay in flash mode, and is detected by the PC.
Someone help me?
Already installed W7 on a new PC, and even then I did.
When I turn, appears unknown device, and will not let me update the drivers.
I've tried everything I read here, have tested the program to install the drivers, and nothing works.
TV Stick: GXT_D16_LP_V1.8 150310
hello
NEEED HELP
Does anyone have a rom for this stick?
have quite a few roms but tried Unfortunately, this does not wifi.
this rom works but no wifi : http://freaktab.com/forum/tv-player-...699#post349699
I've tried this kenel but the wifi does not work : http://freaktab.com/forum/tv-player-...237#post387237
description from ****:
Smart TV Box Stick Android 4.4 Quad Core 2G/8G XBMC DLNA WiFi US MK809IV Mini PCthanks very muchCPURk3188T Quad Core 1.6 (Cortex-A9) GPUQuad Core Mali 400 RamDDR3 2GB RomOn board NAND Flash 8G Expand Micro SDT-Flash(Maximum support 32GB) Video FormatMPEG-1/MPEG-2/MPEG-4/H.263/H.264/AVS/VC-1/RV8/RV9/RV10/VP6/VP8/Sorenson Spark/MVC 1080P@60fps(1920x1080) Audio FormatSupport: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV Picture FormatSupport: Max.8000x8000 JPEG BMP GIF PNG WIFIsupport 802.11a/ b/g/n BluetoothSupport Bluetooth 4.0 OutputHDMIPort Ports1*Micro USB,Support OTG/HOST ( USB port RJ45) 1*standard USB 1*TF card slot 1*Micro USB for power 1*Physical botton(For upgrading software) OSGoogle Android 4.4 Dimension105mm*40mm*10mm DC5V 2A Weight<40g Working environment5C--35CC30%--90% Humidity Storage environment-20C--60CC10%--90% Humidity
Excuse me for my bad english
best regardsYou may only view thumbnails in this gallery. This gallery has 5 photos.5 PhotosLast edited by Sillium; 08 July 2015, 07:43.
Sillium,
try the one from this post: http://freaktab.com/forum/tv-player-...408#post403408
I have the same board. The rom works, with WIFI & Bluetooth. Unfortunately, it is 720p only.
after any reboot its crashing.
do you have the board GTX_D16_LP_V1.6 ? your board have chips from samsung?
my board is GTX_D16_LP_V1.8, my board have other chips. my board have chips from SKhynix. i think thats the problem? i have any idea why its don't work.
I have some of Rome tried but all that has wifi does not work
thanks for your information.
best regards
There are currently 2040 users online. 1 members and 2039 guests.
