Probox2 EX samehardware as Minix X8??
I have the opposite scenario, I have a Probox2 and would like to try the X8-H firmware. The Probox2 firmware seems to handle WIFI very poorly as some of you mentioned and I want to experiment with different software. Do you think it's possible to flash X8-H firmware on a Probox2 without issues? Would you recommend X8-H firmware over Probox2 after trying both?
Originally posted by andoni View PostI have the opposite scenario, I have a Probox2 and would like to try the X8-H firmware. The Probox2 firmware seems to handle WIFI very poorly as some of you mentioned and I want to experiment with different software. Do you think it's possible to flash X8-H firmware on a Probox2 without issues? Would you recommend X8-H firmware over Probox2 after trying both?
2. Can it be done? I don't have a Probox2. But if it works the other way - (and it does...)
There are currently 1819 users online. 1 members and 1818 guests.
