In fact if I used the Yuandao kernel.img with this ROM it boots on my Yuandao N101-1 and everything works!
READ THE README.TXT FILE IN THE ROM KIT PLEASE!
Features in 1.4 ROM:
1) FULL init.d support! Now Scripts put in /etc/init.d will now run on boot.
This means you can now play with the V6 Super Charger stuff, etc
See here for more info:
Note: you do not need to use V6 init.rc integration! You cant anyway.
But it is not needed for V6 since full init.d works.
2) Of course full init.d means full BusyBox install with all needed SYMlinks!
3) This has my ClockWork recovery Mod installed. If you do not want to use it DONT.
On first boot just select reboot now and be done with it!
It will not get in your way again if you do not want it!
Included is Petrus reboot tool which allows you to reboot into recovery from the OS.
If you want to know more about that, read this post:
Other APPs like Titanium will also reboot into recovery so if you dont want the reboot APP, you can remove it.
4) Since /system is now RW, I have increased it's free space to allow rooted and system apps.
5) Installed the latest working SU and SuperUser.apk
6) Updated busybox to 1.19.x (1.20.x has bugs in my opinion) and full busybox install with symlinks.
7) Full Google Play fix applied! Far more APPs should show up in GPlay now.
8) Debloated the ROM of the junk APPs. I also removed the Chinese and Japanese keyboards.
However in the ROM kit is APP Injector. Use that to put back what you want.
See instructions in the README!
OK enough of all that.... here is the download for my 1.4 ROM.
ROM -> Aoson M11 - Finless ROM V1.4 CWM - init.d (170 megs)
Enjoy,
