Talk 9X U65GT grainy screen?
Originally posted by leotzian View PostIt is good you fixed it, that's why I was insisted about root button, when you see root button on MTK droid tools it has to do with rooting not well installedwhen i try to install an apk from my sdcard i have an error about : a problem occurred during the analysis of the android package
If you have a way where i can search....
I'm root and i have also check : install form unknown source...
i am on official rom V2.0 http://i59.servimg.com/u/f59/13/15/39/79/p1120210.jpg
Originally posted by jeko View PostHiu, root is fixed now i have another problemwhen i try to install an apk from my sdcard i have an error about : a problem occurred during the analysis of the android package
Originally posted by jeko View Posti have ES explorer and it is from this app ilaunch the install and got this error.
1)If you have the apk in an external microSD Card try moving it in the internal SD of the tab and try
2)The apk you try to install is not suitable for Kitkat version
3) The apk file is corrupt downloaded it again from another source
Originally posted by jeko View Postok i found the answer , it was the root i have done is not efficient, i use root genius to root again and now it work, i can saved my imei
Thanks in advance
There are currently 2210 users online. 0 members and 2210 guests.
