Pipo P4 RileyROM 1.9
    Originally posted by harpdoc View Post
    I've been using the SendAnywhere app to transfer files between my P4 and my smartphone. I believe this uses your wifi network, rather than wifi direct, but it works well (as long as you're on a wifi network).
    Thanx for info, i'm using similar app but the case for me is sending files through wifi direct.
    Maybe next fw release fix this issue.
      https://www.youtube.com/watch?v=Vb6Lrr9ngrM
      i love this tab
        rrileypm
        a bit off topic question
        but do you know if pipo will create android 5.0 for the pipo p4 ?
        if they wont will you create one ?
          Pipo has tried to keep up with the latest versions of Android...but generally they only support newer versions on new models. With the RK3188 models, KitKat was introduced in beta tests (which I was able to receive and make custom ROM's with), but users reported that Jellybean ROM's were ultimately much more stable.
          The P4 is the only tablet supporting Android 4.4.4...the other RK3288's are all still 4.4.2.
          The key to upgrading to the next level involves having kernels compiled from source code that will support the newer version of Android. As long as those tablets are still in production, that decision is completely up to them.
          I, personally, don't have the ability to compile an Android 5.0 kernel from an Android 4.4.4 tablet.
          Randy
            i see,
            thanks for your answer
            guess all i can do is wait till pipo tell us soemthing
              just did a 1.9.... i got to ask.... is it me or has this opened up the dam and its flooding in now..... this thing is like lightning ?
                glad to hear it's fast!!!!
                Thanks for the donation, BTW!!!!!
                Randy
                  prob did a silly thing here riley.... as the firmware is so good i thought why not give it a go on the hph 2/16 3288 box that i got.... of course its turned into a brick.... help
                    You got me there...I'm not a TV box guy. Check with Finless.
                    Randy
                      hph said to me same system ?..... seems not ?
                        Still getting sleep of death
                        1.9 works great and the tablet really zooms... but I am still getting sleep of death. If I leave the tablet in sleep mode for an hour or more (either charging or not) - it's dead, can't wake it with the power button. I have to hold the power button down to get it to reboot. Then when it comes back from the reboot the display is dimmed to a low level. ...battery is still high
                        I've tried setting wifi off on sleep, no screen lock, minimal apps installed, no apps that need root, with or without smart cover... nothing has helped.
                        Is anyone else seeing this issue?
                        I've been on the RileyRom for so I can't recall if I had this on stock or not... so I want to go back to stock and see if this problem still happens.
                        Randy, can you tell me where I can get the Pipo stock WIFI rom you used as a base for 1.9
                        Thx FredT
                          Re: Pipo P4 RileyROM 1.9
                          Thx FredT
                          I've never seen an SOD with this tablet on any of the ROMs. It could be one specific app you haven't eliminated or a hardware CPU specific thing. Changing WiFi setting to always in standby should prevent tablet from going into deep sleep, though it will consume more battery and sounds like you already tried that.
                          Sent from Tapatalk on my Pipo P4 running RR 1.9
                            Thx FredT
                            I am not sure if you are experiencing the same issue like I do - could you upload a screenshot from the battery options? My tablet turns off randomly, too. This appeared on RR 1.7 and RR 1.9. On stock ROM this battery issue/SOD-thingy did not happen to me.
                            Thanks in advance,
                            so long
                            another
                            Sent from my P4 using Tapatalk
                              Thanks in advance,
                              so long
                              another
                              Hmmm my battery profile right after my problem happens looks very different them yours...
                                Thanks in advance,
                                so long
                                another
                                Hmm right after I posted that I am not seeing what you are seeing I get hit by the same battery drain in sleep as you are seeing.... To be clear this is different from the SOD issue I originally posted which I am also still seeing.... sigh.... I need to find the latest stock firmware to test this.
