http://forum.xda-developers.com/show....php?t=1753473
ZERO Devices Z8C Alice - AllWinner A80 Octa-Core Tv Box
Also long time ago, but if I'm not wrong it should also work with the linux.img
RK3288 Devices
- Overview BOX (LINK !)
thanx no span for your advice!
Your knowlegebase is really amazing.
It's worked perfectly.
I'm working at this time on Linaro Rom (linaro-desktop-cb4-card-hdmi-v0.4). This ROM has advantage, that's possible to logout and restart DE.
Also I tried to install lubuntu-desktop - but I only get problems with cursor sign.
If I want to startup this lubuntu DE, always I was falling back to the login screen - same problem what I was experiancing after installing xubuntu-desktop.
Still a lot of things to improve on this device.
Originally posted by no_spam_for_me View PostAlso long time ago, but if I'm not wrong it should also work with the linux.img
=> http://www.cnx-software.com/2015/04/...d-performance/
The whole img or only the rfs?
Keep us up to date
RK3288 Devices
I used only RFS from the build, because to use the whole image my decive don't startup.
To get it out of the image - I explored with fdisk the img file (sorry it's in German - but whats necessary its shown as numbers)
Allwinner-A80# sudo fdisk -l linaro-desktop-cb4-card-hdmi-v0.4.img
Platte linaro-desktop-cb4-card-hdmi-v0.4.img: 1950 MByte, 1950351360 Byte
255 Köpfe, 63 Sektoren/Spur, 237 Zylinder, zusammen 3809280 Sektoren
Einheiten = Sektoren von 1 × 512 = 512 Bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Festplattenidentifikation: 0x00000000
Gerät boot. Anfang Ende Blöcke Id System
linaro-desktop-cb4-card-hdmi-v0.4.img1 40960 65535 12288 83 Linux
linaro-desktop-cb4-card-hdmi-v0.4.img2 65536 3694591 1814528 83 Linux
Allwinner-A80#
I mounted (-o loop) the img2 file with offset 65536 * 512 = 33554432 to /mnt and got the ext4 RFS.
Allwinner-A80# sudo mount -o loop,offset=33554432 linaro-desktop-cb4-card-hdmi-v0.4.img /mnt
After this operation I made a tarball <linaro-desktop-cb4-card-hdmi-v0.4.tar.gz> and lateron extracted this to my sdcard in mmcblk0p7/sdX7.
After this the A80 starts up and showed the background picture from this build.
BTW wifi don't work out of the box - but at the moment I use ethernet interface for internet access. Maybe lateron I will take a look about this problem.
I'm quite new with this build and when I have more info's I'll share it here.
Keep us up to date
For those who did not check, there is an Ubuntu firmware available for download in www.zero-devices.com website (click on "downloads" menu)Android TV Box direct from China. English & Español
There are currently 6573 users online. 1 members and 6572 guests.
