MK903V ROM OPTIONS
Originally posted by Zahir View PostRoot is built-in. Look for a switch (checkbox) in Settings (under 'Accessibility' or some such tab). Rom should hold up under most conditions, hopefully stutter-free.
mcmoser, thanks for the confirmation, hope my rom continues to stand up for you.
The problem with the ap 6335 model is that there doesn't seem to be a BT driver for that chipset on Lollipop unless someone else knows something different....on the other hand, AC wireless is a definite plus..
Originally posted by Zahir View PostHere you go: download and unrar this file. Flash it (on its own) over the rom you installed, Reboot. You should have wifi.
https://mega.nz/#!Nd4kHSBC!2mbVNrnUf...0KTIoVPSsIaZUY
NOTE: This is a resource image, not a system one.Itried many kodi builds. Only Jarvis 16.1 had PT with a very-very stutter audio, all other buils did n't work.
I put back the KitKat stage-3 rom. From otherside the rom is perfect thank You once more.
I've built a custom image from the RK3288 SDK using the original DTS file, that I exported from resources.img.
WiFi and BT work properly, however when I do "ip addr show" it shows me "eth0", but this board hasn't got a LAN port.
Does anybody know how to remove the ethernet interface from the build target,
is it anywhere in the kernel config or BoardConfig or anywhere else?
Hi
I know this thread has been quiet a while but I am just trying to improve my mk903v 8gb stick (I presume as it is 8gb, it is ap6330?).
I use mine with my Pioneer Appradio as I notice someone else does.
Currently I am on stock kitkat.
I'd like to try the Lollipop, I need BT for the appradio. Can anyone help? Zahir can I still message you privately to get your ROM please? or mcmoser do you have all I need? It seems you have the same setup as me?
Thanks in advance..
Vanginger
Absolutely, all up and running now, thanks so much!
For anyone else interested. mine has the AP 6255 wifi. I flashed the stock 5.1.. from https://chinagadgetsreviews.com/down...-tv-stick.html
Then copied all Zahir img files over. Works great!! BT works with appradio. I don't get the stuttering sound i used to get, google maps works flawlessly now (it used to crash), and I have twrp recovery ( he sent a different one) so I can backup
Thanks again also to mcmoser who also helped out.
Hello, everybody,
I return to the thread because I've been struggling with this stick for a long time, and I still haven't managed to play a streaming video for 30 minutes without issues.
The last thing I did was to flash the rom posted with this link:
But the stick still gets too hot, and the video/audio freezes.
Zahir files aren't availables.
Do you know which rom keeps the stick cooler? Can you play streaming videos without freezing?
Thanks a lot to all of you, you are the best
There are currently 3018 users online. 1 members and 3017 guests.
