Zoomtak T8 and M8 official firmwares
Has anyone removed the motherboard on a Zoomtak M8 (black metal box model)? Looks like the only entry point is via 4 small screws in the plastic back panel that holds all of the connectors?
Got one here that has been damaged in transit - something rattling around insideLive as if you were to die tomorrow. Learn as if you were to live forever
Originally posted by jellywobbles View PostHas anyone removed the motherboard on a Zoomtak M8 (black metal box model)? Looks like the only entry point is via 4 small screws in the plastic back panel that holds all of the connectors?
Originally posted by stane1983 View PostHi,
I talked to Zoomtak SW engineer about doubts which device is which.
Here are list of Zoomtak S802 devices:- T8 (single band wifi - 8188eu, without bluetooth)
- T8 V2 (dual band wifi with bluetooth)
- M8 (dual band wifi with bluetooth)
There are two ways of identifying T8 device. 1st, if you don't have Bluetooth settings in Settings app, you have T8 (first version), otherwise T8 V2. 2nd, on bottom of box should be written on sticker V2 which stands for T8 V2 version.
Install instructions:
Download all files, put them to root of sdcard and power device on with recovery button pressed or select .zip file from Upgrade app inside Android.
These are not mine firmwares so I don't accept feature requests lol, but you can write some feedback here, maybe Zoomtak staff will read this thread
Zoomtak firmware 3.4.2:- T8 V2 & M8 - stane1983.com
- T8 V1 - stane1983.com
reflash it v2 then, did you have bluetooth prior flashing?- T8 (single band wifi - 8188eu, without bluetooth)
Bugs are Sons of Glitches!
JustMe
There are currently 1737 users online. 0 members and 1737 guests.
