Ubuntu (Linux) system firmware of Nagrace HPH
it would be the boot linux,img. i extracted the ugoos dualboot img in rk3xxx firmware tools. linuxroot.img is 2 gigabytes and looking at the hph image recovery is bootlinux.img hph images is in9 parts but the ugoos is 1 file thats why i extracted it. the hph bootlinux file is 8 megs and the ugoos is 18 megs. not sure if i want to try flashing a regular recovery then rooting and flashing bootlinux.img back. what ya think?The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Originally posted by jacko View Postmo123,
I see you have called the dual rom a Ugoos rom, does that mean its built from Ugoos firmware ?
Anyway i have a Ugoos UT3 16gb so i can test if you want.
Regards Jacko.
Edit,
I am now downloading the dual boot rom from Ugoos to test, but i would rather use the mo123 dual rom as he will have made it better for sure
The Ugoos UT3 kernel doesn't support 2 partitions on external storage, but should work now with a mixture of HPH/UGOOS firmware files.
i just tried what you suggested no spam for me and it worked. i flashed a reg recovery installed update.zip from external sd and now im rooted. reflashed bootlinux and all is well. thanks again bro for the info.The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Where can I find the dual-boot download links for
Ugoos
HPH
and which linux version do they use?RK3288 Devices
- Overview BOX (LINK !)
another thing about this ugoos dual boot is that the android os only has 0.95gb of app space on internal storage. nand says 9.40 total with 8.35 remaining. i dont want to have to use folder mount for asphalt 8 and MC5. mo123 once your done with your custom dualboot i will be flashing it asap bro. we all appreciate the great work you do brotha.
a 4gb app space partition would be awesome moLast edited by ICU; 29 November 2014, 10:38.The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
ubuntu 14.10 bro. heres the link to the ugoos http://ugoos.net/blog/ugoos-ut3-android-linux-dualboot
i would prefer it was ubuntu 14.04 lts
Originally posted by no_spam_for_me View PostWhere can I find the dual-boot download links for
Ugoos
HPH
and which linux version do they use?The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
ya the 1 gig of app space has to be changed. its useless. my spmc folder is 600 megs. i cant restore all my backups from titanium not enough space lol. like dual boot is great but having only 1 gig is wack. 4 gb would be great!!! also needs to be rooted. i dont like not having full control over the box it drives menuts. lolThe funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Originally posted by ICU View Postubuntu 14.10 bro. heres the link to the ugoos http://ugoos.net/blog/ugoos-ut3-android-linux-dualboot
Where can I find it?RK3288 Devices
Originally posted by no_spam_for_me View PostDoes it mean, HPH is also 14.04 (like firefly) ?
Also 14.04
Were the 1st company besides firefly that made a dual-boot firmware.
And now Open Hour also released their Lubuntu 14.04 firmware
It runs of micro-sd card and is not dual-boot.
Originally posted by mo123 View PostHPH Linux dual-boot firmware is in the 1st post of this thread.
But they are different form the first version of firefly (201409291637) ... but I only quick checked it via compare using WinHEX...RK3288 Devices
Originally posted by no_spam_for_me View Postok, ok, ok, you are right (but it could also be that they meanwhile released a newer version)
Maybe will hear something next week after they also looked at my other suggestions.
Anyway, both HPH and UGOOS use the same boards and the firmware is interchangeable, so not a problem.
4gb app space possible bro?
Originally posted by mo123 View PostIt's only that version, but I asked that their engineers check for a new version and also look at the UGOOS one.
Anyway, both HPH and UGOOS use the same boards and the firmware is interchangeable, so not a problem.The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Originally posted by leo5111 View Posthow does linux run on the hph 4g? do we have hardware acceleration?
Rockchip is working on it, but without the support of ARM releasing the drivers, don't know if it will ever be possible.
There are currently 2125 users online. 1 members and 2124 guests.
