Fixing Streaming APPs that crash or wont work S802/805, etc
    OK folks, time to start a new thread about trying to fix or at least figure out why some streaming APPs crash.
    1) Bell TV APP can be fixed by editing build.prop and remove this line:
    hw.nophone=false
    Or comment it out by putting a # in front like this:
    #hw.nophone=false
    Now the biggest issue I think we will find with these APPs is they are calling wake_lock but do not have permission to do so. Until AML fixes the SDK there maybe a way to get them working.
    For instance, I edited the PBS APK and simply added this line to manifest.xml and repacked the APK.
    <uses-permission android:name="android.permission.WAKE_LOCK" />
    That got it working.
    So if anyone wants me to see if I can fix other streaming APP for you, post here.
    I may need you to send me the APK if I cannot get it here in the USA.
    I will update this threads with links to fixed APPs.
    First up PBS APP
    Demand 5.
    Next?
    the ones not working in the uk are all on googleplay all free apps they are bbc iplayer /demand 5 and 4od the last 2 play adverts but wont play any proggrames they had worked on every rom update so far but not on 2
    good luck
      good luck
      OK the BBC iPlayer APP. Either I am not seeing it as I am in the US or something else. I see a BBC iPlayer APP made by BBC iPlayer. It is only a radio APP not TV.
      I also do not see 4od player in the play store and I also do not see Demand 5.
      I even tried going to google play with my PC and a web browser. Cant find them!
      So you may have to send me the APKs.
        I think this is the 5OD apk
        And the 4od can be gotten here
        This is just a quick off the top of my head reply - not done any kind of testing etc.
        Oh and this is the BBCIplayer link (maybe UK IP's only)
        Team UX
        http://www.ultimatexbmc.com/
        http://www.freaktab.com/showthread.p...-ULTIMATE-XBMC
          https://play.google.com/store/apps/d...player.android
          When I go to Google Play for 4oD I get this:
          This app is incompatible with all of your devices.
          Someone send me the APK please.
            If you guys want me to fix this stuff, I need the APK's please. I cant get them from place store since I am not in the UK.
              4od if iv done it right https://drive.google.com/file/d/0Bzq...ew?usp=sharing
                Originally posted by blinkone View Post
                Nope, APK is no good. Close but I cannot even unpack it.
                Please try again if you can.
                Also the demand 5 APP is old and when I run it, it says update to the latest and I cannot when I click play store as it says not available in my country
                  I have another go, I don't use the apps but im hear to help if I can I will ree download & try again, I dont no if im doing things right I downloading the app then backing it up
                    Will do my best to see if I can do some RnD on this for you, will get back to you in a couple of hours, unless I see another solution posted.
                    Team UX
                      I don't no if this is any help bob but hears a titanium backup of the apk https://drive.google.com/folderview?...zQ&usp=sharing
                      I don't no of any other way to get the apk to you as it vanishes when it installs
                      Or theres this if your brave enough its a update.zip of the app..BUT bear in mind i aint got a clue what im doing ha ha,, i made the zip with an app called zipme its a android app ,,i think you can just put it on your sd card & you install it via recovery https://drive.google.com/file/d/0Bzq...ew?usp=sharing
                      Oh the update zip is for a 3288 device
                        APK was good this time
                        BUT, when I run it and click on a video the APP says "4od is not available in your location".
                        So I took the APK apart anyway and it already has the wake lock command in it.
                        So that rules that out!
                        I can't help any more on that APP since it wont work for me in the USA
                          Titanium back up of demand5 https://drive.google.com/folderview?...0E&usp=sharing
                          Demand5 update zip https://drive.google.com/file/d/0Bzq...ew?usp=sharing
                            twrp backups from my vega-h i even rarred them individually just in case, these apps do work on my phones just not on the vega-h after last rom update
                            cheers
                              OK demand 5 should be fixed. APK download in first post.
                              However I cannot test for sure as when I click on a video I get a message that I am not in the UK.
