Seems something to do with the status bar or something.
Maybe someone with better eyes than me can see something here:
I/ActivityManager( 609): start package name is com.gotv.crackle.handset, class name is com.gotv.crackle.ShowWatchlistDetailsActivity, error code is 0
W/Crackle - UALib( 2689): Activity com.gotv.crackle.MainActivity@420684f8 was not manually added during onStart(). Call UAirship.shared().getAnalytics().activityStarted in every activity's onStart() method.
E/com.newrelic.agent.android( 2689): Failed to detect New Relic instrumentation. Something likely went wrong during your build process and you should contact [email protected].
E/SessionM( 2689): SessionM activities must be presented on resumed (non-paused) activities. Activity cannot be presented because currently running Android activity is unknown. Ensure your activity properly calls SessionM.onActivityXXX() notification methods or extends com.sessionm.api.BaseActivity.
D/dalvikvm( 2689): GC_CONCURRENT freed 1625K, 28% free 11822K/16264K, paused 4ms+7ms, total 72ms
D/dalvikvm( 2689): WAIT_FOR_CONCURRENT_GC blocked 66ms
I/ActivityManager( 609): Displayed com.gotv.crackle.handset/com.gotv.crackle.ShowWatchlistDetailsActivity: +281ms
D/AndroidRuntime( 2689): Shutting down VM
W/dalvikvm( 2689): threadid=1: thread exiting with uncaught exception (group=0x41ed0ba8)
E/AndroidRuntime( 2689): FATAL EXCEPTION: main
E/AndroidRuntime( 2689): Process: com.gotv.crackle.handset, PID: 2689
E/AndroidRuntime( 2689): java.lang.NullPointerException
E/AndroidRuntime( 2689): at android.support.v4.view.MenuItemCompatHoneycomb.se tShowAsAction(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v4.view.MenuItemCompat$HoneycombMe nuVersionImpl.setShowAsAction(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v4.view.MenuItemCompat.setShowAsAc tion(Unknown Source)
E/AndroidRuntime( 2689): at com.gotv.crackle.BaseMediaDetailsActivity.onPrepar eOptionsMenu(Unknown Source)
E/AndroidRuntime( 2689): at com.gotv.crackle.ShowWatchlistDetailsActivity.onPr epareOptionsMenu(Unknown Source)
E/AndroidRuntime( 2689): at android.app.Activity.onPreparePanel(Activity.java: 2598)
E/AndroidRuntime( 2689): at android.support.v4.app.FragmentActivity.onPrepareO ptionsPanel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivity.superOnPr epareOptionsPanel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivityDelegate.o nPrepareOptionsPanel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivity.onPrepare OptionsPanel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v4.app.FragmentActivity.onPrepareP anel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivity.superOnPr eparePanel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivityDelegateIC S.onPreparePanel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivity.onPrepare Panel(Unknown Source)
E/AndroidRuntime( 2689): at android.support.v7.app.ActionBarActivityDelegateIC S$WindowCallbackWrapper.onPreparePanel(Unknown Source)
E/AndroidRuntime( 2689): at com.android.internal.policy.impl.PhoneWindow.prepa rePanel(PhoneWindow.java:464)
E/AndroidRuntime( 2689): at com.android.internal.policy.impl.PhoneWindow.doInv alidatePanelMenu(PhoneWindow.java:800)
E/AndroidRuntime( 2689): at com.android.internal.policy.impl.PhoneWindow$1.run (PhoneWindow.java:221)
E/AndroidRuntime( 2689): at android.view.Choreographer$CallbackRecord.run(Chor eographer.java:772)
E/AndroidRuntime( 2689): at android.view.Choreographer.doCallbacks(Choreograph er.java:585)
E/AndroidRuntime( 2689): at android.view.Choreographer.doFrame(Choreographer.j ava:554)
E/AndroidRuntime( 2689): at android.view.Choreographer$FrameDisplayEventReceiv er.run(Choreographer.java:758)
E/AndroidRuntime( 2689): at android.os.Handler.handleCallback(Handler.java:733 )
E/AndroidRuntime( 2689): at android.os.Handler.dispatchMessage(Handler.java:95 )
E/AndroidRuntime( 2689): at android.os.Looper.loop(Looper.java:136)
E/AndroidRuntime( 2689): at android.app.ActivityThread.main(ActivityThread.jav a:5034)
E/AndroidRuntime( 2689): at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 2689): at java.lang.reflect.Method.invoke(Method.java:515)
E/AndroidRuntime( 2689): at com.android.internal.os.ZygoteInit$MethodAndArgsCa ller.run(ZygoteInit.java:788)
E/AndroidRuntime( 2689): at com.android.internal.os.ZygoteInit.main(ZygoteInit .java:604)
E/AndroidRuntime( 2689): at dalvik.system.NativeStart.main(Native Method)
W/ActivityManager( 609): Force finishing activity com.gotv.crackle.handset/com.gotv.crackle.ShowWatchlistDetailsActivity
I/Process ( 2689): Sending signal. PID: 2689 SIG: 9
D/ActivityManager( 609): send app_CRASH broadcast, packageName:com.gotv.crackle.handset
W/InputDispatcher( 609): channel '42679968 com.gotv.crackle.handset/com.gotv.crackle.MainActivity (server)' ~ Consumer closed input channel or an error occurred. events=0x9
E/InputDispatcher( 609): channel '42679968 com.gotv.crackle.handset/com.gotv.crackle.MainActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
W/InputDispatcher( 609): channel '4235d100 com.gotv.crackle.handset/com.gotv.crackle.DetailsActivityResolver (server)' ~ Consumer closed input channel or an error occurred. events=0x9
E/InputDispatcher( 609): channel '4235d100 com.gotv.crackle.handset/com.gotv.crackle.DetailsActivityResolver (server)' ~ Channel is unrecoverably broken and will be disposed!
W/InputDispatcher( 609): channel '424ac0e8 com.gotv.crackle.handset/com.gotv.crackle.ShowWatchlistDetailsActivity (server)' ~ Consumer closed input channel or an error occurred. events=0x9
E/InputDispatcher( 609): channel '424ac0e8 com.gotv.crackle.handset/com.gotv.crackle.ShowWatchlistDetailsActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
I/ActivityManager( 609): Process com.gotv.crackle.handset (pid 2689) has died.
W/ContextImpl( 609): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1162 com.android.server.am.ActivityManagerService.onVid eoPlayerCrashed:3689 com.android.server.am.ActivityManagerService.handl eAppDiedLocked:3719 com.android.server.am.ActivityManagerService.appDi edLocked:3857 com.android.server.am.ActivityManagerService$AppDe athRecipient.binderDied:1046
W/InputDispatcher( 609): Attempted to unregister already unregistered input channel '42679968 com.gotv.crackle.handset/com.gotv.crackle.MainActivity (server)'
W/InputDispatcher( 609): Attempted to unregister already unregistered input channel '424ac0e8 com.gotv.crackle.handset/com.gotv.crackle.ShowWatchlistDetailsActivity (server)'
W/InputDispatcher( 609): Attempted to unregister already unregistered input channel '4235d100 com.gotv.crackle.handset/com.gotv.crackle.DetailsActivityResolver (server)'
I/WindowState( 609): WIN DEATH: Window{42679968 u0 com.gotv.crackle.handset/com.gotv.crackle.MainActivity EXITING}
I/WindowState( 609): WIN DEATH: Window{424ac0e8 u0 com.gotv.crackle.handset/com.gotv.crackle.ShowWatchlistDetailsActivity}
I/WindowState( 609): WIN DEATH: Window{4235d100 u0 com.gotv.crackle.handset/com.gotv.crackle.DetailsActivityResolver}
I/ActivityManager( 609): Start proc com.gotv.crackle.handset for activity com.gotv.crackle.handset/com.gotv.crackle.MainActivity: pid=2824 uid=10058 gids={50058, 3003, 1028, 1015}
