M-195 REALTEK 1195
    M-195 REALTEK 1195
    My initial taught after testing the device for 2 days.
    This are i few things i have tested.
    XBMC -display setting 720p Default ( Can't Change)
    XBMC playback (rtkplayer=can't play any file)
    4K media playback - Not Working
    3D Bluray ISO - Working with mediabrowser app
    • Jellyfish-120-Mbps.mkv 120 Mbps – Working
    • AC3 – Works
    • DTS 5.1 - Works
    • Dolby Digital 5.1 - Works
    • TrueHD 5.1 & 7.1 – Not Working.
    • DTS-MA and DTS-HR 5.1 & 7.1 – Not Working
    More testing and video coming.
    Hello Movie78, I've been curious about this box. How does it handle other Android duties like game play, web surfing, etc?
    Thanks for the post.
    -RISCy Dude
      Kernel.config for M-195:
        http://pastebin.com/r4TMtitL
        What i'm suppose to do with it?
          Nothing yet, it is just for information.
            Thanks!
            Are you developer for This Product?
              No, I'm not. I've sent you a PM on Kodi forum with a modded firmware.
                Thanks!
                I am going try it later on today.
                Are you going to get this device?
                The file you sent me it encrypted.
                message :Enter decryption key
                  You probably copied wrongly the download link(it includes a decryption key too).
                  Try this:
                  Dropbox download link:
                    Try this:
                    https://db.tt/vbhEdylL
                    Dropbox is much better.
                    Thanks!
                      Try this:
                      I received my ew902 yesterday. Is this the recent firmware for the box? Have you found a way to connect to windows computer? Thanks
                        It's for m-195.
                          It's for m-195.
                            @Movie78
                            So have you tried the firmware? Does it work? Is it better than newer firmware?
                            I think they changed from 1080p to 720p in Android to get better score in Antutu.
                              This patcher patches firmwares from 720p to 1080p. Patch works on M-195 & newer EW902 firmwares too. which aren't 1080p.
                              The modified firmware wasn't tested, but it should work. Test at your own risk!
