M-195 REALTEK 1195
    Originally posted by Movie78 View Post
    I have no issue playing movies from XBMC,
    Are you playing files from USB or NETWORK (NAS)?
      Originally posted by davdi1982 View Post
      Are you playing files from USB or NETWORK (NAS)?SMB
      Both..
        Both..
        Thanks, I really don't know why my xbmc can't play files.
        For network movie, are you using NFS or SMB?
        What is temperature of you chipset after playing a movie?
        Edit: I have test the upnp protocole for adding network source video and it works from xbmc. Do you have an idea why NFS and SMB doesn't work?
          I amusing using SMB w/ Windows 8 Share no issue,
          I haven't try NFS yet, SMB works
            There is new firmware for the Eweat and Zapitti 4k that fixes the HD AUDIO issue.
            I am wondering when we will get on this device.
              12/12/2014 firmware is the same as pub_sdk6_1080_1127_install firmware.
                This make me crazy !!! How the hell can XBMC work both with SMB and External drive connected with the M-195 when my EWEAT player CAN'T load ANY file from my computer with WINDOWS 8 SMB, DLNA ?
                I contacted Vicky Yang to ask her why the hell the firmware updates are working on the M-195 but not on the EWEAT ? They provide better firmware updates on the M-195 as it seems.
                She told me that their company are producing also the M-195 and that the M-195 firmware are made by their people.
                So why are you bringing 1080p patches for the M-195 but you are not providing it on your website for the EWEAT ?
                She told me bla bla bla that they are working for the XBMC issues and will fix it soon. Really ? It"s been since last october and you have done NOTHING or WORSE ( 1080p to 720p drop in Android and XBMC )
                to fix XBMC issues.
                Their programmers must be very bad not be able to rectify these issues.
                And those files : AVI, XVID, DIVIX, WVM9, WMA, WMA PRO are not working on the EWEAT and they should. She even send me a data sheet of the Realtek chipset compatibility
                  Yes!
                  Still waiting for the HD Audio Firmware..
                  I try flashing the M-195 with Eweat latest firmware,but the device get stuck I boot screen.
                    Probably they changed something minnor to prevent cross flashing .With a little programming knowledge someone will be able to flash other 1195 firmware.It will be great if we could flash zappiti firmware to m-195 ...
                      Movie78, could you test this firmware(it's 1127 firmware with a few modified files) for HD audio playback?
                        http://goo.gl/UbCkuL
                        Sure
                        Is this Eweat latest firmware modified?
                        PS: I get error when extracting the zip file.
                        Can you use a different upload client?
                        Thanks!
                          Yes it uses some files from latest eweat firmware.
                          MD5 of m-195_1127_mod.7z:
                          32f3140afc319890859292b2d6ec5d47
                          It's a 7zip archive try 7-Zip archiver for unpacking:
                          Here is uploaded to Dropbox:
                            https://dl.dropboxusercontent.com/u/...95_1127_mod.7z
                            Thanks!
                            Will test this tonight..
                            Will XBMC work with the default player RTKPlayer?
                            Their last update broke the fonction..
                              Just test the Firmware..
                              Still no HD Audio(DTSHD or Dolby TrueHD)
                                Is this firmware permit to have a working XBMC ?
                                For information, I have installed an aluminium heatsink to avoid overheating problems, and now the temperature still @70°C, Before it can raise 90°C.
