M-195 REALTEK 1195
Originally posted by TitoXx View PostSo is Zappiti firmware any better than what we currently have?
Sent from my A0001 using Tapatalk
It seems that the zappitti could read files from NFS protocole, but there are not much improvments.
It would be great to get a zappiti firmware to check it.
Ps: I am trying to change the m-195 install.img using the install.img from eweat, but the new file doesn't work, nothing happen whan I try tu update firmare. I a am using 7zip or winrar. Is there a trick?Last edited by davdi1982; 09 February 2015, 15:17.
flashing firmwares
Originally posted by davdi1982 View PostIt seems that the zappitti could read files from NFS protocole, but there are not much improvments.
let me know...
If eweat doesn´t work, flash zappiti firmware...it´s the same as newer eweat´s frimware...is a huge file because it has a lot of app inside, more than eweat´s default...
Originally posted by herhelman View PostOK, i don´t know if there is a trick....but certains firmware doesn´t shows video out (hdmi or av, same) so you have to put the flash drive, turn on the device with the reset pressed for 5 seconds and then,,,wait 5 minutes... the only thing you can do is to check the blinking light of the flash drive....
let me know...
Thanks for your reply, will test the original eweat soon, but it seems that it is not woking bettre than before :'(. I think that I have to keep a full computer has mediacenter.
Originally posted by Movie78 View PostI was able to install the Zapitti recovery firmware on the M-195 without any issue.
The Zapitti firmware have too many unnecessary apps installed,hope someone can clean it up.
The M-195 patcher 720p to 1080p UI doesn't work with Zapitti Firmware.
Thanks,
David
https://dl.dropboxusercontent.com/u/...15/install.zipOriginally posted by davdi1982 View PostHello, do you have a link for the zappitti firmware?
Thanks,
David
Hello, I have an error 509 with your dropbox link, could you please check this?
Many thanks,
D.
zapitti firmware
Originally posted by davdi1982 View PostHello, I have an error 509 with your dropbox link, could you please check this?
Many thanks,
D.
DON´T expect anything from zappiti firmware....same as eweat with a lot of unnecessary set of worthless app.... zapitti player 4k needs a token extracted from device sticker...like the windows license one behind every windows laptop, it will not work...also it´s not working well as people are saying on the zapitti forum.
I´ve been flashing for fun back and forth.... dont waste your time and risk your devide...realtek needs to provide a patch for 23,976 playing, and a well written Kodi custom version... but, for now... just use any realtek 1195 device with eweat´s lastest 2 firmwares.... they´re stable with RKT player.
For me, they need to correct:
awful subtitle font...just one horrible font, and , in a 2.35 ratio movie...they´re behind back bars and you need to re position up to see it.
NOT 23.976 support, a small but visible glitch every 41 sec
NO BD iso menu, 1186dd old generation realtek chipset supported almost perfectly .
media player has a fixed sorting...i think is fixed by downloaded or created date.
thats my 2 cents advice...
Originally posted by herhelman View PostLink was down for a while...dont know if now is working.
Thanks for your feedback, i would like to check if nfs is supported from XBMC , because on my m-195 I can't use XBMC because it is not supporting that.
Originally posted by csgabe View Post@Movie78
m-195.1080p.patcher.1.1 works for zappiti firmware:
Deselect backup if you don't want to wait that much during patching & don't want a 1.5GB backup file created.
Delete .BAK
Its there a way you can remove all those unnecessary apps?
Thanks!
zapitti firmware
Originally posted by csgabe View PostI think it's possible to remove the unnecessary apps by mounting & modifying ext4 partition.
It's the same firmware as eweat and probably slower... even if you can hack zapitti 4k player, people who actually spent 250 euros on their device, are complaining in zap forum...check for yourself...
But, if you want to clean the firmware, just install it and uninstall the apps with app manager as normal apps on a normal android phone.... all the apps that comes with zapitti are normal and cleanable... like..amazon app, netflix, bbc news...etc...
Just got a new one and wanted test it again,but wonder if this would happen again.
Can you please look into the new Zapitti firmware?
There are currently 1807 users online. 0 members and 1807 guests.
