Because I don't have it now, I use Bob's first impressions to have a starting point...
Draco AW80 - Multimedia playback and XBMC issue & feedback here
I start some explicit threads to sort all issues and feedbacks from the beginning...
Originally posted by Finless View PostOriginally posted by Finless View PostOriginally posted by Finless View PostOriginally posted by Finless View PostOriginally posted by no_spam_for_me View PostOriginally posted by Finless View PostOriginally posted by Finless View PostLast edited by no_spam_for_me; 07 November 2014, 16:46.RK3288 Devices
- Overview BOX (LINK !)
Fly Mouse Mini Wireless Keyboard with 2 mode learning IR remote 'iPazzPort KP-810-16'Tags: None
FYI
Originally posted by alwaysbless View PostHave been testing with this device for approx a day now and some of the stuff on this box seems like its downgraded compared to previous version smh. For one, my video quality doesnt even look as sharp as my chromecast =/ It literally looks like its reverted it to 480p
Netflix also has trouble with controls while video is plying (e.g. If i try and fast forward the moment i navigate to the bottom bar it auto hides itself and ceases to fully display again unless i exit the video completely)RK3288 Devices
Originally posted by Zeggi View PostDoes anyone know if the device supports DTS/DD5.1 playback and also if the audio is delivered in 5.1 over HDMI?Looking for developers
FYI
Originally posted by alwaysbless View PostDid you try changing the DPI from 160 to 240? That fixed the problems I had with video playback.Originally posted by Moulin1980 View Postthank you alwaysbless, ( ok geekbuying, the problem is resolved )
For the video :
1080p720p film in streaming = perfect
4K sata, stuttering a bit less with MX player.
with Bsplayer, strong stuttering.
with KODI, does not work.
movie playback in sata :
with kodi - Film MKV 720p --> stuttering a bit
With MxPlayer - Film MKV 720p --> ok perfect
With BsPlayer - Film MKV 720p --> ok perfect
For the audio :
DTS 5.1 = ok, is perfect
For the sata :
I wrote an error with the SATA, I now erase.
Now it works when I connect the sata at startup.
( DO NOT HAVE THE BOX DRACO, UNDER VOLTAGE ), otherwise does not start for me.
I'm An updated and other correction on my first post.RK3288 Devices
Originally posted by Finless View Post...
FYI the frame skipping on MKV's is like the old days of 3188.... It's in the kernel!
It's a software decode.
If you remember PHJ Anderson's kernel patch way back on 3188 kernels.... Same thing.... Pretty sure it is anyway.
Originally posted by Zahir View PostI see. And that would fix the stutter/judder I notice on many, if not all, true 1080p videos?
I thought the issue might be linked to the dropped frames you can see counted in this snapshot. The clip is a 1080p mkv at 45 mbps (Jellyfish). The same clip runs much more smoothly in MX Player.[ATTACH=CONFIG]8779[/ATTACH]Originally posted by 1Ramsey1 View PostDisappointing, drops at 45mbps, with 60 (or whatever) active cores on GPU!!?!!
Originally posted by Zahir View PostThanks, I followed that good suggestion before running that 1080p Jellyfish clip. The dpi change improved some things, but hasn't addressed what I fear is a conflict between XBMC and the PowerVR drivers.
Another story I'm wondering in is the fps at the W(...-row, because at the RK3288 I have fps:23.98 which is nearly the fps of 23.976 instead of the 10.56 I can see at the AW80...
All-in-all I think there is much optimizing potential for the kodi-team to get a good working version at the AW80....
(BTW: in the past they work at the Amlogic (MX) but they also need some time to optimize it for the S802... but don't ask me why they are able to release nice working versions for RK3288 much faster)RK3288 Devices
You are quite right that there is great scope for optimizing XBMC video on this new platform.
Compare these two debugs of that 1080p mkv at 45 mbps.
The first is Gotham 13.2. The second is SPMC. Note the improvement in SPMC in:
a) fps; b) vcpu utilization; c) frame drops. On the other hand, frame skips increase. The video runs twice as smoothly in SPMC as in Gotham, but still not at its full potential (23.9 fps).
I hope Tronsmart are reading this. There is work to be done between their software people and the XBMC team.Last edited by Zahir; 15 November 2014, 11:13.
Originally posted by Zahir View Post... Gotham 13.2 ...
But nice to see the different results at SPMC (koying rules).
BTW: often the drops and skips at debug are not corresponding with reality (you can see the same effect at amlogic but not with your eyes)...RK3288 Devices
Originally posted by geekbuying View Posti have already tested the dts and dolby. use the stock player and xbmc to play videos. 5.1 audio is no problem to passthrough over HDMI and optical.
Update: I noticed on build.prop settings:
audio.output.active=AUDIO_CODEC,AUDIO_HDMI
audio.input.active=AUDIO_CODEC
I changed to:
audio.output.active=AUDIO_CODEC,AUDIO_HDMI,AUDIO_S PDIF (spacing is ok on build.prop)
Still does not work...My only other option is to reflash....but this should not be happening to a new device...might wait for Finless new rom for this device...Last edited by freakkid; 15 November 2014, 13:20.
Originally posted by no_spam_for_me View PostIs it Stock or the 'normal' downloaded version?
Originally posted by alwaysbless View PostNetflix comes in the same as other android tv boxes - Very watchable quality but not HD like on the amazon fire tv.
There are currently 1542 users online. 0 members and 1542 guests.
