OS API = 19
Draco AW80 - Multimedia playback and XBMC issue & feedback here
Originally posted by freakkid View Postif DTS and Dolby is working for you then I must have defected hardware.....How do I check for defected hardware (obviously software is ok if working for you) to prove hardware defect...device is with original firmware...I might have to return for defective hardware!! When I select pass thru spdif (and select spdif in settings) I get no sound at all..only thru hdmi. Works fine with my transmont s9 elite...
Update: I noticed on build.prop settings:
audio.output.active=AUDIO_CODEC,AUDIO_HDMI
audio.input.active=AUDIO_CODEC
I changed to:
audio.output.active=AUDIO_CODEC,AUDIO_HDMI,AUDIO_S PDIF (spacing is ok on build.prop)
Still does not work...My only other option is to reflash....but this should not be happening to a new device...might wait for Finless new rom for this device...
i will test here for you.
you should change the passthrough in the setting.
EricLooking for developers
I've tested a bunch of different XBMC versions on the stock rom to see if any handles 1080p better.
I found one that is smoother than any of the official releases: this custom version of 13.2 from the people behind XBMC Hub.
Don't ask me why, but it handles 1080p better, with almost no frame drops and fewer frame skips. Here's that famous opening scene in Transformers Extinction that produces frame drops and judder on every other XBMC version I tried. This one isn't perfect - but noticeably smoother.
Download and HowTo install the TVMC
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by geekbuying View PostLet me know what videos you use for testing?
Eric
Professional software products for video analysis and monitoring, IPTV solutions, digital broadcasting and video streaming, transcoding and VOD-servers.
Nice library of test vids!
i just got my Draco and everything has a stutter, skip in kodi?
Also it does not see channel 136 on 5ghz wifi. No problem on my vega s89h or minix x8h.
And i sold my minix 😢
out of the box imma not to happy .)Uno MAS
Raspberry pi 2 > osmc
Ouya
Vega s89H > finless 2.1
Minix X8-H plus
rii i8+ & rii i25A & Yatse
FYI
Originally posted by Moulin1980 View PostLink (KODI helix Beta3) : http://kodi.tv/download/
Tested with Finless ROM 1.0 - BETA
Streaming video :
Film MKV 1080p --> now it works perfect, ( before,stuttering a bit )
before, the film takes a long time before starting.
now the buffer is perfect
VIDEO : test via HDD sata
Film MKV 720p --> now it's perfect. ( before it stutters )
codec h265: test via HDD sata
now it works, but stuttering ( before, it does not work )
4K : test via HDD sata
Audio :
DTS 5.1 - does not work for me. ( before, it worked with KODI Beta2 )
------------------------------------------------------------------------Originally posted by Zahir View PostYes indeed - the one or two add-ons I could get working did stream very smoothly.
But if you use XBMC to stream from the internet, Kodi/Helix is an exercise in frustration: of the 12 add-ons I use most often, only two work. And I installed them all from a Helix repo, too.
So, back to 13.2 and stuttering 1080p for me...RK3288 Devices
FYI last night the wife and I watch 2 movies from 1Channel (don't tell anyone).
Life of PI and Cloud Atlas.
We saw NO stuttering or skipping. In fact my picky wife said this was the best she had seen as far as streaming goes. This I am sure has do to the fastest WIfi speeds on any box I have seen yet. Usually when streaming over WIFI on any other box, there sometimes is a stick spot, skip, jump etc.... We had none.
Just what I saw last night using the box real time.
Originally posted by MAS View Posti just got my Draco and everything has a stutter, skip in kodi?
let me know how you test, which video do you use for testing? do you streaming online or play local files?
Originally posted by Finless View PostFYI last night the wife and I watch 2 movies from 1Channel (don't tell anyone).
Haven't tried wifi yet (fails to see my 5ghz network) but my 180Mbit wired wont go past 95Mbit. in speedtest wich should still be more then enough i think.
I dont mind using 3rd party rom (your rom is keeping my vega happy) but it shouldn't be necessary.
For now ill use the vega till im brave enough to attempt to flash the finless rom.Uno MAS
Ouya
Minix X8-H plus
Originally posted by geekbuying View PostJust submit the 5ghz wifi problem to factory, now back to the stutter problem, come on ,man, don't just tell me everything has a stutter.
Eric
Thanks for the 5ghz help!
I only stream content, no local files tested yet.
Up till now i got the stutter on genesis, any movie in channel, tv show big bang theory 1080p, there even the sound slows down, ustvnow, 1channel, cartoon hd, mlbmc
The youtube app in android seems to work just fine.
"upgraded" to helix beta 3 but that didnt seem to help.
Its 3am, done looking for today. .)
Tomorrow fresh start, i'll factory reset and begin again.
masUno MAS
Ouya
Minix X8-H plus
New Insight into Stutter
I think the libstagefright codec may be part of the issue with XBMC stutter on this box. I turned it off in Settings/Playback/Acceleration and did the 45mbps jellyfish video test again. (You must have your Settings mode at Advanced or Expert level to access the acceleration tab).
Major improvement in smoothness, now nearly equal to how smoothly the file plays in MX Player.
Would like to know what others see. Try the 45mbps file here as a baseline.
Update: just streamed two full 1080p movie segments from Navi-X. Both were problematic before. Both played almost perfectly with libstagefright switched off...
I think this is the start of a permanent solution!Last edited by Zahir; 11-18-2014, 04:53.
Originally posted by Zahir View PostI think the libstagefright codec may be part of the issue with XBMC stutter on this box. I turned it off in Settings/Playback/Acceleration and did the 45mbps jellyfish video test again. (You must have your Settings mode at Advanced or Expert level to access the acceleration tab).
Upate: just streamed two full 1080p movie segments from Navi-X. Both were problematic before. Both played almost perfectly with libstagefright switched off...
There are currently 1480 users online. 5 members and 1475 guests.
