Next, we should try to develop an advancedsettings.xml tuned to this box that improves video buffering, now that high bitrate files can be streamed painlessly..
Draco AW80 - Multimedia playback and XBMC issue & feedback here
Thanks for that response and insight. I'm now certain you'll see a major improvement with these two tweaks, dpi at 240 and - most important - libstagefright off.
Originally posted by Zahir View PostHow'd you like that Richard Parker, Bob? Quite something, for a CGI tiger, huh?
Glad that your evening was glitch-free. In the end, it's about enjoying what the moment brings. (I think 1Channel streams in 480 or 720p, not 1080p, where our issues are noticeable).
Me.... I know the second was the truth..... Yet the story of the tiger was good.....
Life.... and how you like to tell it....
Cloud Atlas was strange.... Guess you have to believe in reincarnation! I for one do not.
I do not understand this skipping and stuttering issue as I have not seen it. Just watched tonight the last week playing of Bing Bang with NO issues! I am scratching my head
Pi: while I suspected that the second tale was true, it had me praying that the first was - which was the point of the yarn, I guess.
Stutter: it's an observable issue with high bitrate files that's apparent to a number of us. The libstagefright fix makes a large positive difference. Take a look at some jellyfish.
i have just installed tvaddons fork and that looks promising!
First thing i tried on genesis runs smooth!! ? no more stutter(freez, its more like it freezes, like every 2 seconds it freezes 0.01second)
I noticed that preparing for first run takes a lot more time, 30 seconds+ where on other devices its less then 10?
edit: ha, think i found it, stutter on my end comes with stereo upmixLast edited by MAS; 18 November 2014, 12:26.Uno MAS
Raspberry pi 2 > osmc
Ouya
Vega s89H > finless 2.1
Minix X8-H plus
rii i8+ & rii i25A & Yatse
Originally posted by MAS View Posti have just installed tvaddons fork and that looks promising!
Have you tried turning off libstagefright? That should pretty well fix your micro-stutter/freeze issues.
Originally posted by Zahir View PostWith libstagefright turned off: very smooth panning in the opening scenes of A Christmas Carol (2009) at 1080p. Note the number of CPU cores engaged !
Still some skipping, but not noticeable.
, mine just uses 2 on what i tried, libstage on or off..
Uno MAS
Ouya
Minix X8-H plus
Originally posted by Zahir View Post@alwaysbless, nice to see you on here. From previous experience, I know your eyes see what mine do - and another pair on this fix is helpful.
Does turning off stereo upmix and downmix as well improve things even further?
@MAS, to see the cores engaged, switch to the Eminence skin.
my kodi uses 2 cpu's until nowUno MAS
Ouya
Minix X8-H plus
Hi all, I have a problem with Kodi Beta 3 ( Link : http://kodi.tv/download/)
I tested with "Finless ROM 1.0 - BETA" a video 720p with DD sata.
setting/System/Setting Level Expert/Audio output :
(libstagrefright activate or no, it's the same)
With this configuration, DTS 5.1 is ok, but video stutter.
Enable passthrough -------------------> on
Dolby Digital (AC3) capable receveir --> on
- Enable Dolby Digital transcoding ----> on
DTS capable receiver ------------------> off
With this configuration, DTS 5.1 does not work, but video is perfect.
- Enable Dolby Digital transcoding ----> off
I don't own this box yet ... But observation from my side is that libstagefright had to be turned off with the XBMC video addons on my S802 box, I tested this on my old box into oblivion and sometimes forgot to disable it. Sounds like Allwinner suffers from the same issue.
Sent from my iPad using Tapatalk
There are currently 2175 users online. 0 members and 2175 guests.
