NEW!! pureX KitKat V1 - New firmware for CX-921 and CX-919
    Will this rom work with cx-919 t chip version if so which kernel would you recommend please.
      Should work with posted kernel link for tv stick from first post. Please test and report back.
      Walter77
      Gesendet von meinem iPad mit Tapatalk HD
      Donations are welcome and will be shared with other devs:
      DONATIONS
      CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
        Originally posted by walter77 View Post
        Should work with posted kernel link for tv stick from first post. Please test and report back. Walter77 Gesendet von meinem iPad mit Tapatalk HD
        The kernel you posted with pureX works with the cx-919. However I ran into two problems. One, when I enable 1080p60, small thin red lines will randomly speckle the screen. This doesn't happen with 720p. Another problem is that when I try to play video from the BTN2go app, the video comes up mainly black and white rather than with proper colors. Not sure if this is simply a kernel problem, since it occurs in all builds that I have tried. All other video seems to play correctly. Lastly, do you think mpeg-2 hardware acceleration will ever be supported? Thanks.
          I'm not sure, have you tried something like this?
          Learn how you can enable Developer options and turn on USB Debugging and OEM unlocking on Android devices running Android Marshmallow, Nougat, Oreo and Pie.
          Walter77
          The problem is that the " Build number" is not visible for me to click on it and enable the developper option. The Rom has it hidden. how can i enable it then?
          I found this developper options on google store. it did the trick. what i wanted was to disable the stay awake setting activate usb debugging
          for those that are interested the link is http://m.downloadatoz.com/apps/net.s...ns,313076.html
            https://play.google.com/store/apps/d...eloper_options
            Thanks for the info and sharing the link.
            Walter77
            DONATIONS
              hi, I can load it in h5 box wifi AP6330?
                You can trie but you will need another kernel for working ethernet and wifi.
                Walter
                DONATIONS
                  Walter
                  hello, thanks for the reply, I tried different firmware, but always beautiful with wifi not working, I wanted to find a kitkat clean for my h5, is not very stable and does not work to its original resolution in 1080, I'm not good with Android, beginning now, there is some firmware that I can try? Thanks, and sorry for my english
                    Walter
                      I've been trying to flash this on my MK908II. Flashing itself seems to work okay, but upon booting I always get stuck on the image of the android with red exclamation mark. I've tried tens of times.
                      I can without problem go back to another rom, eg a928_4.4.2_kk_finless20 .
                      Originally posted by LawlessPPC View Post
                      What an absolutely amazing rom. Im running it on a MK908II (RK3188T, AP6210) with d33 kernel (4.2.5) 720p) booting from a class 10 sd card. Antutu scores between 26126 and 26365. Bluetooth responce is the best ive witnesed on any rom (no stutter). Would you know a way of stopping enter key on bt keyboard also triggering left mouse button click, both actions happen on pressing enter key? Again best rom ive used and ive tried loads as long as its been for a rk3188. Im considering releasing some sd card images of your rom for people with bad onboard nand chips (if thats ok with you?) but ive not managed to get hdmi passthrough working at least not for dts and dolby digital but i need to play more, unless you have any suggestions?
                      I'd like to make sure the sd card images run as well as you have so patiently made sure your builds do
                      Thanks again absolutely brilliant work
                      LawlessPPC
                      Hi LawlessPPC, i'd like to try that route with the sd card. Is the image ready you think?
                      MK908II T
                        I want free Microsoft office
                        Works great on my CX-919.
                        Even support multilingual hardware keyboard.
                        But i have a problem with ms Microsoft Word, Excel and PowerPoint.
                        MS Offide apps don't edit documents on devices with more than 10.1" display for free.
                        I read somewhere i need to edit videodriver config.
                        Now xdpi=160, ydpi=160.
                        How i can change values to 240?
                        ro.sf.lcd_density is not working here.
                        Can some one help me with this problem?
                        Sorry for my bad english anyway.
                          Best kitkat rom so far for my mk908ii with d33 kernel.
                            CX-919
                            Hello I have installed,
                            pureX_KitKat_V1_cx921a
                            everything is working well just tv remote is not.
                            I am attaching photo of the remote and mother. Please make kernel for me. Please help.
ID:	437279Click image for larger version
                              I'm trying to flash this rom on a MK908II but no success so far. Other MK908ii users have done it so I know it works. I flashed items 1-7 in the look_inside folder, exchanging the kernel for the AP6210 4.2.5 kernel by D33. I've tried SD, HD and the alt ones. but all I'm getting when booting is 4 penguins in the top left and the the image of the android on it's back with a red exclamation mark on it. Can anyone tell me where I am going wrong?
                                I had exactly the same problem.
                                I can't remember the correct order of how i was able to flash it, but it involved using the flasher of another firmware, mixing img parts, changing the parameters and a lot of trial and error. Once i got past the android with exclamation mark i got stuck on a looping boot logo. Kept trying and now it works.
                                Another option would be to boot from SD, but i haven't looked into that.
                                This is indeed the best rom so far formy MK908II. Thanks!
                                MK908II T
