[PIPO Project] M8HD
Unzip the file, and use RK AndroidTool single rom image file to flash.
After you can/should flash TWRP and a different kernel.
Tapatalked
Sorry, I'm not very clued-up with all this so I've no idea how to provide any of those things! A bit og googling shows that I could use an app, but no wifi means no playstore, or there seem to be other routes requiring more skills, or more time than I presently have to invest in acquiring them.
Oh dear. I tried to reboot it but it got stuck with the torch on and the image of an android on its back, with the front open and a red triangle with an ! hovering over it. I had to reset it. I've got a twrp recovey on an sd card, but not sure how to proceed as the device is not recognised by my computer any more so I can't access any tools to reflash. Is there a way I can get windows to see it? And if not then what can I do? There aren't many options under settings - no developer options at all. Anyone able to offer any advice?
Press power for 10 secs to be sure it's completely turn off.
Boot it up, assuming that system boots, open settings, about tablet, press 5 times on build number to enable developer settings. On developer settings goto advance reboot and enable it. Long press power button and reboot to boot loader.
Or enable adb and reboot to boot loader from command line.
Or use button combination to boot to boot loader.
That's a pretty strange description of what happen.
Tapatalked
Sorry, I missed your previous post. Everything works so far as I can tell - bluetooth is fine, and the battery usage is miles better than it was with the other ROM. The only problem at the moment - that I can find -is that wifi doesn't work, and I can't get either of the flashing tools to see the tablet. Just tried to boot to boot loader following the first option but it didn't happen. Tried to boot to recovery and arrived at the sick android with the red triangle hovering over it and the torch on again
There are currently 3979 users online. 1 members and 3978 guests.
