[PIPO Project] M8HD
Originally posted by abdul_pt View PostCan you provide log's ? dmesg and logcat
Anything else ?
Hopefully someone with this HW will jump in.
Thanks for your good work.
I will try maybe next week when I get some time.
Wifi on M8HD is AP6210, and I think files is missing in etc/firmware/nvram_ap6210.txt and maybe others
I think I've managed to sort out the battery drain on the original ROM. I know a few other people have mentioned this so thought I'd post what I've done as maybe it will be of use to others. I'm obviously a bit of a newbie with this stuff so let me know if this makes no sense or is just plain stupid!
So the problem has been that the tablet drains in around 2 to two and a half hours. It also took about 6 to recharge. This isn't much use if you want a portable device. It's down to my m8 being the version without 3g. So, I uninstalled anything that looked like a telephone using titanium, but that didn't seem to have much effect - mainly because nothing was actually getting uninstalled. So instead I disabled all the telephony stuff via settings/apps. I disabled com.android.smspush, dailer, email, exchange services, and network location. The battery was charging while I did this and I've attached a screenshot that shows the rapid drain, the slow charge and then the sudden leap when I disabled the apps. I suspect network location is the one causing the drain, but that's just a guess. Does this make sense? So far the battery seems to be draining much slower than before. I'll update later if anyone is interested.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
As mentioned on another thread either:
1. Rename the ril library (/system/lib/libril-rk29-dataonly.so )
2. turn on 'Airplane mode' - wifi and bluetooth can be toggled on/off even with this on!
Donate to Finless
Sorry to be banging on about this (and the double posting above) but in fact there wasn't much improvement. The screenshot shows that even in airplane mode and with everything disabled 'cell standby' is still using loads of battery. I've gone for the renaming the ril library method which has now reduced the usage figure to 3% rather than 13%. Maybe this method will finally stop it draining the battery!You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I've got 0.3% battery drain per hour in deep sleep.
percentage : 27% less in 3d 6h 30m with 30% cell standby : => approximately : 12 days standby !
We can desactivate some service in boot.img as I do before but this boot will be only for wifi tablet.
But as I remember, You will not get many less battery drain.
I do still have the M8HD lying around here and from time to time I do recharge it.The battery is still in a very good condition.
I am writing this post currently on this old tablet. :-)
What has been the latest custom ROM for this device and is that still available somewhere?
I know I had installed in 2014 a 4.4.2 version on it (probably a Riley version, build number has the timestamp 20140219.181341).
And are the sources still available somewhere?
There are currently 1819 users online. 1 members and 1818 guests.
