MK808 Android mini TV Player - Finless ROM 1.4 Custom ROM
    It's not the antenna it how 2.4 Wifi is implemented on the device or your router! It is suppose to channel HOP when it sees it is on a noisy channel. This is how spread spectrum works. Many wifi devices should not interfere with each other!
    So again this could be your router not supporting it or the device. Bottom line if the wifi spec is implemented properly, devices should not interefere with each other until there are over 255 devices on in range of each other.
    FYI, I do not have any ossues like your talking about. I have 4 wifi devices on in my home and none are messing with each other.
    Read this here about how this is all suppose to work:
    This Spread Spectrum tutorial information is provided to you by Pegasus Technologies, a consulting company specializing in innovative, state-of-the-art engineering solutions for today's RF, wireless and Spread Spectrum needs.
    Specifically:
    Frequency hopping systems -- The wideband frequency spectrum desired is generated in a different manner in a frequency hopping system. It does just what its name implies. That is, it "hops" from frequency to frequency over a wide band. The specific order in which frequencies are occupied is a function of a code sequence, and the rate of hopping from one frequency to another is a function of the information rate. The transmitted spectrum of a frequency hopping signal is quite different from that of a direct sequence system. Instead of a [(sin x)/x]^2-shaped envelope, the frequency hopper's output is flat over the band of frequencies used. Figure 2 shows an output spectrum of a frequency hopping system. The bandwidth of a frequency hopping signal is simply w times the number of frequency slots available, where w is the bandwidth of each hop channel.
    And a little more info here:
    Thank you Bob. It's clear now. I, too, have three devices simultaneously connected in the same WiFi with no problem.
    Should it be that I have specifically set the channel number on my access point? I'll check this weekend.
    Thanks again,
    P.S. have you checked a camera with build in mic with Skype?
      4.1 JB USB Sound
      Its my understanding that usb sound was a feature of Jelly Bean?
      I'm unable to make a usb soundcard work on my device using the Fitness rom.
      Is the card I'm refering too, is there a way to make this work?
      Also,
      I thank you very much for your rom, it has worked the best out of everyone i've tried!
      PS
      Geekbuying failed to provide the promised kernel update today
        Hello,i have tried this rom on my ss808 and its perfect.
        Though i have a small problem. I am using a rc11 fly air mouse, but the volume buttons doesnt work
        Does anyone has the same problem
          Working great here, thanks Bob
          Gave you a mention in my mini review.
          Jez
            bt dongle support coming soon?
              Jez
              Mini review? I would love to see it! Post a link please.
              edit: OK I see you gave a link..... I could not tell...
              For those that want to read the review and did not see Jezzers link... here it is:
              http://dragondevs.com/index.php?/top...8-mini-review/
                Installed the ROM, everyhting works very nice. Thanks
                  Hi Bob,
                  do you plan to bring new Custom ROM for MK808, since factory early today released new firmware? Currently available under Stock firmwares @armtvtech.
                  BR,
                  BooLE
                    Hope so, +1 for this...
                      It is 4:30AM at Bob's right now but I am sure he will once he sees there is an update.
                        Yes, I have the new ROM and will do a custom ROM for it ASAP.
                          Re: MK808 Android mini TV Player - Finless ROM 1.4 Custom ROM
                          Good news thanks Bob.
                          Jez
                            You have to get up pretty early to be up earlier than Bob.
                              New 1.5 ROM almost ready!
                              OK my new MK808 1.5 ROM based on the latest release is almost ready!
                              It took me HOURS but I think I fixed the wifi crap with it dropping to 5mbs and sticking there!
                              It works for me anyway. For sure I have a wifi performance improvement with my patch. Again at least based onmy testing.
                              I am also going to include both launchers like in the ug802 and the new MX1. So you have a choice on boot which you like and can always switch between the two.
                              I debloatied this thing and added 2GB of apps space.
                              I also have just made a few more tweaks and I just have to build it and test fully now.
                              So hopefully I will have my ROM out today! If not for sure tomorrow bright and shinny
                              You guys are going to love this new ROM I think
                              Well at least I hope so!
                              bob
                                bob
                                Idea to bring in MX1 launchers is great - afaik they are prepared by Rockchips, so I guess you will also add settings, and setting applications like in MX1. Please don't forget reboot application, and if possible please leave original boot logos.
                                Thanks, and give yourself time to prepare everything, we will be steady-ready for testing.
