I ASK THAT YOU FIRST TRY the 100% Yaundao ROM first for video/audio sync testing! PLEASE....
Remember WE ARE TRYING to fix video/audio sync issues!!! That's all these BETA ROMs are about! Do not expect a refined ROM here!
This BETA2 ROM is for POWER users only. I will NOT be making a BETA update.img package. You must use my Flash tool and have the drivers etc ready to go. If we fix the sync issues then YES I will make a update.img package as a final ROM.
PLEASE READ the README in the package and what I ask you to do to flash this.
Here is a summary of the readme:
Note: Both the 2 system.img files are using the Yaundao EGL screen drivers, LIBs, etc.
Expect some screen artifacts like twinkeling, dots, etc.
We are trying to test sync issues not details. Once we find the GOAL, I will fix the other issues.
But this could come down to the EGL drivers, etc. We shall see from testing!
There are 2 system.img files in this beta test!
1) SystemBETA2a.img which is a complete Yaundao system.img. Lets see if it has sync issues at all?
You will not be able to get into the ug802 advanced settings etc.
To flash a new ROM again use the reboot APP and reboot to bootloader! ONLY WAY!
Also YOU WILL need a physical USB keyboard.
This ROM will NOT pop up a virtual keyboard so be ready for that.
This ROM will have lots of stuff not working but wifi works, APPs work, etc
Again this is to test sync issues PLEASE TRY IT even with all it's problems!
2) SystemBETA2b.img which is a 98% Yaundao ROM but with ug802 resource files, etc so more works!
Virtual keyboard works, advanced settings etc, etc etc.... BUT not everything works yet. e.g. screen stretch!
To set HDMI resolution use the regular settings NOT the advance ug802 settings (it will crash).
To flash this ROM system.img is not set by default! It will not flash unless you select one of the system.imgs
On the right of the system line in the flash tool is a little empty box.
Click it and navigate to FinlessROM folder and select one of the system.img files.
Now erase NAND (IDB) and flash the entire ROM.
Now to switch between the 2 system.img files.
YOU DO NOT HAVE TO ERASE NAND and reflash the entire ROM.
But I do ask that user data be erased. This happens when flashing misc.img.
However, you are free to try switching without flashing misc.img thus installed apps and account settings will NOT be erased. But for best testing, flashing misc.img is prefered.
So to switch between the 2 system.img files do the following
1) Be on one of these ROMs already!
2) Run the flash tool
3) Uncheck everything except MISC.img and one of the system.img files.
If you want to try not erasing user data then also uncheck misc.img.
4) In the ug802 run the reboot app and select "reboot bootloader"
5) Now flash misc.img (optional) and system.img
Easy peasy to switch to test everything!
Download the BETA2 ROM here:
ROM -> ug802 Finless 1.5C ROM - BETA2 TEST of audio/video sync (300 megs)
Let me know!
OH and please... can we keep replies here focused on the BETA TEST please. NO QUESTIONS about should I or shouldnt I flash kind of thing. Again I am looking for POWER users here. If you think you are one, feel free.
