Thread: ug802 Finless 1.5C -- BETA TEST #2 ROMs (dual ROM test)
    so it means we still have a chance for better firmware? ))))
      I am betting NOT.... the ug802 the wifi drivers are built in the kernel. Every ROM I have tried to port this has been the issue. Only because the Yaundao has the same hardware does my 1.5C ROm work. I doubt the MK802-3 has the same hardware. But if it does..... we could be in business.
        It changes nothing if the drivers built in or not, if the wifi adapter is the same it has to work... I hope there's only rtl8188 and rk901 that chinese manufacturers are using?...
          N101-2 & UG802
          What about N101-2. I've heard compared to the first model in this also different drivers wi-fi. The second model can fit it to our UG802? You can certainly try the firmware from the second model? Мaybe they are similar?
            What do you think this 1.5C ROM is made from? Yuandao N101-1 ICS ROM.
            Same hardware. Pretty sure the first post says that?
              N101-2 & UG802
              I'm talking about the second version, they have different wifi modules. and maybe the second version is similar to our
                No the first version is! Again this is what I used for 1.5C. The 2nd version if wifi is different then it wont work!
                WAIT.... EDIT..... you might be right. I am still using the ug802 kernel for wifi in 1.5C.
                Let me have a look and I will try it.
                  is there any info about update ?
                    I will be 100% honest with you. I am not sure how much farther I can go on this project. I am sorry.
                    I will continue but using other ROMs, while it fixed or helped the AV sync issues, I cannot fix some of the other issues related to the kernel!
                    WE NEED A FREAKIN KERNEL FROM UGOOS!
                    EVERYONE BUG THE HELL OUT OF THEM FOR IT!
                    Thats my best advice.
                      thank you for fast reply but the funny thing is my unit doesn't have sync issue. I've tried in 2 different tvs and the sound seems normal to me in you tube and in mx player, i didn't try 1080p videos yet but youtube hd works good... and the tvs are toshiba regza lcd tv and 2011 model lg led tv, I don't remember actual model info of tvs and Im now outside of my country so I can not look into that.
                      I was just looking for native autohide feature and proper shutdown app.
                      thank you for your hard work.
                        Oooo-NO
                        Thats very disappointing. Ugoos will do nothing.
                        We are fubared.
                          Cmon Bob you can do it. I only have joined to this website because of you Bob. That idea can go to dev->null dir... Im going to try it out. I have noticed if youtube is used with default firmware its not that bad. When does it get bad? Well if you are watching live flash streams. Video will be late good 2-4seconds. You click play, audio plays, video freezes and thats how problem start.
                            You know it's not too likely to happen.
                            The dealers that buy from ugoos should have got us a new ROM already but they have not so we need you not to quit!
                              geekbuying released the pictures of mk802III pcb and it really looks like ug802, I couldn't see the model number of wifi chip but it looks like same chip, maybe Bob can receive the jb firmware of the mk802III ?
                                YES it's Realtek ralink adapter, we're saved )))
