Overclocked RK3288 kernels
VIO is probably Video Input Output (Video Decoder/Encoder). It isn't part of the GPU.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Did you forgot to change DDR voltage? 1,25V should be sufficient but it can always be higher i.e. 1,3V. I tested my DDR3 with 1,35V and 700MHz.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
You are funny guys... why to use tools if I can use e.g. WinHEX
If you use e.g. Android Image Kitchen (http://forum.xda-developers.com/show....php?t=2073775) you will find out, that your boot.img not only contains the kernel (.\split_img\boot.img-zImage), no, also the resources (.\split_img\boot.img-second)...RK3288 Devices
- Overview BOX (LINK !)
@no_spam_for_me. It is much quicker to use Hex editor to OC than to split image and join it back after modification. Another plus is that editing this file can be performed completely "in house" (under Android). I use Hex editor and Hex Plus calculator from Google Play store. Then you can use dd comand to write modified image back.
@tabnk. OC VIO1 engine will probably speed up video decoding but I do not know what voltage it can use and it could be hardwired to 1,1V which will considerably limit max working stable frequency.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
:RK3288 Devices
Overclocked VPU to [email protected].
No improvement at all in KODI (with Rockchip Library) playback a 60mbps 4K MKV.
There are currently 3089 users online. 0 members and 3089 guests.
