I think pretty smooth.
OpenELEC for WeTek Play
Originally posted by Jönke View PostBut i'm pretty shure you can see slowdowns on the fast bar once a minute or so, if you run the hole video, right ? I really hope you can get true 23,976 hz going on your Openelec builds so it can be perfect !
Keep up the good work
Guest
Originally posted by paul_1991 View PostHow can I get the wifi working?
Guest
Guest
Hello Guys... I have installed the last available img of OpenElec for Wetek Play . Then I updated it to the build of 17 Jan 2015.
I have installed tvheadend but it doesn't recognize the DVB-S Tuner... I can't see any tv adaptors in the web menu
Originally posted by paul_1991 View PostHello Guys... I have installed the last available img of OpenElec for Wetek Play . Then I updated it to the build of 17 Jan 2015.
the most simple, pull the SD card, and a new record!«Сомалійська Наноелектроника та Космонавтика»- VS-IP015 - Android Sat Receiver - g18ref_th2
- WeTek Play - Android Sat Receiver - g18ref
Guest
There are currently 6280 users online. 1 members and 6279 guests.
