I have compiled firmware version 2.0 for installation through modrecovery CWM or TWRP.
Made on the basis U65GT_V2.0_update_aatt_20141115
Changelog:
1. Fully deodex.
2. Scrubbing applications in Chinese, including viral.
3. The modified FM radio works without headphones, thanks dimid.
4. Made a fix faulty statistics discharge and frequency of the processor.
5. Reduce the minimum level of manual brightness and Auto Brightness
6. Advanced Power Menu with the ability to download a recovery, thanks for the help dimid.
8. Implement a program to change the system font. Thank hartec.
9. Modified boot.img: mode permissive, support init.d, USB debugging by default.
10. Root on the basis of applications SuperUser from Clockworkmod.
11. Author bootanimation and Bootlogo.
12. Changed platform.xml
13. Chrome works, checked
14. Add line Engineer Menu in Settings\Developer Options
Flash only on tablets with serial numbers higher than B1426xxxxxx ... otherwise there may be problems with the touch screen!
Download
U65GT_V2.0_en_mod_Lepi_20141206.zip
MD5: cb55cfccc7ff4b09ae5f08a4c04ecc55
Firmware reuploaded.
Who downloaded the test-version, please download again.
Installation Instructions:
Only for installation through modrecovery CWM or TWRP!
Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
There are no guarantees! Risk and assumes responsibility fully by the user.
Preliminary backup is required!
Successful upgrade!
